跳转到主内容
Steam Deck OLED Screen Replacement
你所需要的
  1. Steam Deck OLED Screen Replacement, Prepare your Steam Deck for disassembly: 步骤 1 中的图像 1,2 Steam Deck OLED Screen Replacement, Prepare your Steam Deck for disassembly: 步骤 1 中的图像 2,2
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
  2. Steam Deck OLED Screen Replacement, Mark your opening picks: 步骤 2 中的图像 1,3 Steam Deck OLED Screen Replacement, Mark your opening picks: 步骤 2 中的图像 2,3 Steam Deck OLED Screen Replacement, Mark your opening picks: 步骤 2 中的图像 3,3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. Steam Deck OLED Screen Replacement, Heat the top edge screen adhesive: 步骤 3 中的图像 1,1
    • Prepare an iOpener and apply it to the top edge of the screen for one minute.
    • You may also use a hair dryer or heat gun, but be careful not to overheat the device, as the screen, battery, and plastic frame are all susceptible to heat damage.
  4. Steam Deck OLED Screen Replacement, Apply a suction handle: 步骤 4 中的图像 1,2 Steam Deck OLED Screen Replacement, Apply a suction handle: 步骤 4 中的图像 2,2
    • Apply a suction handle to the top left corner of the screen, as close to the top edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
  5. Steam Deck OLED Screen Replacement, Insert an opening pick: 步骤 5 中的图像 1,3 Steam Deck OLED Screen Replacement, Insert an opening pick: 步骤 5 中的图像 2,3 Steam Deck OLED Screen Replacement, Insert an opening pick: 步骤 5 中的图像 3,3
    • Pull up on the suction handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    • Don't insert your pick deeper than 3 mm (~1/8 of an inch) to avoid damaging the screen panel, ambient light sensor, or sensor cable.
  6. Steam Deck OLED Screen Replacement, Remove the suction handle: 步骤 6 中的图像 1,2 Steam Deck OLED Screen Replacement, Remove the suction handle: 步骤 6 中的图像 2,2
    • Pull up on the nub on the back of the suction handle to remove it from the screen.
  7. Steam Deck OLED Screen Replacement, Screen information: 步骤 7 中的图像 1,3 Steam Deck OLED Screen Replacement, Screen information: 步骤 7 中的图像 2,3 Steam Deck OLED Screen Replacement, Screen information: 步骤 7 中的图像 3,3
    • As you slice through the adhesive securing the screen, note the following:
    • Along the top and bottom edges, don't insert your pick deeper than 3 mm (~1/8 of an inch) to avoid damaging the sensors, sensors cable, or screen cable.
    • Along the left and right edges, don't insert your pick deeper than 5 mm (~1/5 of an inch) to avoid damaging the screen panel.
  8. Steam Deck OLED Screen Replacement, Reposition the pick: 步骤 8 中的图像 1,3 Steam Deck OLED Screen Replacement, Reposition the pick: 步骤 8 中的图像 2,3 Steam Deck OLED Screen Replacement, Reposition the pick: 步骤 8 中的图像 3,3
    • Rotate the pick so its flat edge is between the screen and frame.
    • Leave this pick inserted to prevent the adhesive from resealing.
  9. Steam Deck OLED Screen Replacement, Separate the top edge adhesive: 步骤 9 中的图像 1,3 Steam Deck OLED Screen Replacement, Separate the top edge adhesive: 步骤 9 中的图像 2,3 Steam Deck OLED Screen Replacement, Separate the top edge adhesive: 步骤 9 中的图像 3,3
    • Don't insert your pick deeper than 3 mm (~1/8 of an inch) along the top edge.
    • Insert another pick in the top left corner.
    • Slide the pick toward the power button to separate the adhesive securing the top edge of the screen.
  10. Steam Deck OLED Screen Replacement, Reposition the pick: 步骤 10 中的图像 1,3 Steam Deck OLED Screen Replacement, Reposition the pick: 步骤 10 中的图像 2,3 Steam Deck OLED Screen Replacement, Reposition the pick: 步骤 10 中的图像 3,3
  11. Steam Deck OLED Screen Replacement, Heat the right edge screen adhesive: 步骤 11 中的图像 1,1
    • Heat the right edge of the screen for one minute.
  12. Steam Deck OLED Screen Replacement, Separate the right edge adhesive: 步骤 12 中的图像 1,2 Steam Deck OLED Screen Replacement, Separate the right edge adhesive: 步骤 12 中的图像 2,2
    • Don't insert your pick deeper than 5 mm (~1/5 of an inch) along the right edge.
    • Insert another pick just below the right thumbstick.
    • Slide the pick to the bottom right corner to separate the right edge adhesive.
    • Leave the pick inserted to prevent the adhesive from resealing.
  13. Steam Deck OLED Screen Replacement, Heat the bottom edge adhesive: 步骤 13 中的图像 1,1
    • Heat the bottom edge of the screen for one minute.
  14. Steam Deck OLED Screen Replacement, Separate the bottom edge adhesive: 步骤 14 中的图像 1,3 Steam Deck OLED Screen Replacement, Separate the bottom edge adhesive: 步骤 14 中的图像 2,3 Steam Deck OLED Screen Replacement, Separate the bottom edge adhesive: 步骤 14 中的图像 3,3
    • Don't insert your pick deeper than 3 mm (~1/8 of an inch) along the bottom edge.
    • Insert another pick in bottom right corner along the bottom edge.
    • Slide the pick to the bottom left corner to separate the bottom edge adhesive.
  15. Steam Deck OLED Screen Replacement, Lift the top edge of the screen: 步骤 15 中的图像 1,3 Steam Deck OLED Screen Replacement, Lift the top edge of the screen: 步骤 15 中的图像 2,3 Steam Deck OLED Screen Replacement, Lift the top edge of the screen: 步骤 15 中的图像 3,3
    • Grip the two picks along the top edge.
    • Pry up to lift the top edge of the screen away from the frame until you can grab it.
    • If the screen feels stuck, go back around the perimeter and check for missed sections of adhesive. If you're using a hair dryer, use it to lightly heat the stuck sections of adhesive.
  16. Steam Deck OLED Screen Replacement, Flip the screen over: 步骤 16 中的图像 1,3 Steam Deck OLED Screen Replacement, Flip the screen over: 步骤 16 中的图像 2,3 Steam Deck OLED Screen Replacement, Flip the screen over: 步骤 16 中的图像 3,3
    • Be gentle with the screen, as straining its cable may damage the socket on the motherboard.
    • Flip the screen over the bottom edge of the frame.
    • Prop up the screen with a small box or book roughly 2.5 cm (~1 inch) thick.
    • If you don't have a box or book nearby, hold the screen in this position for the next two steps.
  17. Steam Deck OLED Screen Replacement, Unlatch the screen connector: 步骤 17 中的图像 1,2 Steam Deck OLED Screen Replacement, Unlatch the screen connector: 步骤 17 中的图像 2,2
    • Use the point of a spudger or a clean fingernail to flip up the locking flap on the outside edge of the screen ZIF connector.
    • Don't touch any of the small surface-mounted components around the connector.
  18. Steam Deck OLED Screen Replacement, Disconnect the screen: 步骤 18 中的图像 1,2 Steam Deck OLED Screen Replacement, Disconnect the screen: 步骤 18 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers or your fingers to grip the screen cable pull tab and slide the cable straight out of its socket to disconnect it.
  19. Steam Deck OLED Screen Replacement, Remove the screen: 步骤 19 中的图像 1,1
结论
To reapply adhesive and install your screen, follow this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
另外一个人完成了本指南。
Clay Eickemeyer
于09/19/22注册
67,259 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,420篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 48
过去 7 天: 311
过去 30 天: 1,256
总计 4,419
