跳转到主内容
加入维修社区 - 创建账户
Stapler Maintenance
    1. Stapler Maintenance, Open & Identify: 步骤 1 中的图像 1,2 Stapler Maintenance, Open & Identify: 步骤 1 中的图像 2,2
      • Be careful while handling staples or any sharp object in general.
      • Grab the base of the stabler, and pull the hammer until the stapler opens, revealing the carrier, pusher, and spring.
      • Identify the staple type by looking on the bottom of the carrier. If the staple type is not on the carrier, look under the base.
      询问修复机器人
      添加评论
    2. Stapler Maintenance, Insert Staples: 步骤 2 中的图像 1,2 Stapler Maintenance, Insert Staples: 步骤 2 中的图像 2,2
      • Get a cluster of staples and carefully place it in the carrier.
      • Make sure there is enough room for the pusher to contact the staples.
      • Close the stapler by clearing your hand from under the crimp area and pushing the hammer down until a clicking sound is heard.
      询问修复机器人
      添加评论
    3. Stapler Maintenance: 步骤 3 中的图像 1,1
      • Don’t staple your hand, or anyone else for that matter.
      • Congratulations! You have successfully replaced staples in your stapler.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
2指南评论
Wnen I tried to load the staples, the spring came loose. But I do not know where to reconnect it and have a loose short plastic rod!
Brian Gray - 回复 分享
@ cookie clicker When I attempted to load the staples, the spring became detached. However, I'm unsure where to reattach it, and I now have a loose, short plastic rod.
Nadia Eira - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 50
过去 7 天: 561
过去 30 天: 2,716
总计 59,015
