简介
Use this guide to refill and empty stapler, so you can get back to those TPS reports.
Grab the base of the stabler, and pull the hammer until the stapler opens, revealing the carrier, pusher, and spring.
Identify the staple type by looking on the bottom of the carrier. If the staple type is not on the carrier, look under the base.
Get a cluster of staples and carefully place it in the carrier.
Make sure there is enough room for the pusher to contact the staples.
Close the stapler by clearing your hand from under the crimp area and pushing the hammer down until a clicking sound is heard.
10等其他人完成本指南。
2指南评论
Wnen I tried to load the staples, the spring came loose. But I do not know where to reconnect it and have a loose short plastic rod!
Brian Gray - 回复 分享
@ cookie clicker When I attempted to load the staples, the spring became detached. However, I'm unsure where to reattach it, and I now have a loose, short plastic rod.
Nadia Eira - 回复 分享
