跳转到主内容
Spy Net Ultra Vision Goggles Infrared Lights Replacement
你所需要的
  1. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Open the Device: 步骤 1 中的图像 1,1
    • Remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Pry open the shell using the plastic opening tools if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
  2. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: 步骤 2 中的图像 1,3 Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: 步骤 2 中的图像 2,3 Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: 步骤 2 中的图像 3,3
    • Find the infrared light assemblies, which are located at the front end of the device on either side of the lens.
    • The process is the same regardless of which light you are replacing.
    • Lift the light assembly away from the rest of the device.
  3. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Open the Light Assembly: 步骤 3 中的图像 1,1
    • Use the plastic opening tools to pry open the light assembly.
  4. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Disconnect the Lights: 步骤 4 中的图像 1,1
    • Use the soldering iron and desoldering braid to de-solder the wires from the lights.
    • Check out This Guide for tips on soldering and de-soldering connections.
结论
另外一个人完成了本指南。
Travis Kempf
于09/22/14注册
198 声望
撰写一个指南
团队
USF Tampa, Team 4-5, Brown Fall 2014 USF Tampa, Team 4-5, Brown Fall 2014 的会员
USFT-BROWN-F14S4G5
3 名成员
创作了6篇指南
一条评论
thanks for the help
vincentarriesgado - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 831
