跳转到主内容
加入维修社区 - 创建账户
Sprout Channel Cubby Speaker Replacement
你所需要的
    1. Sprout Channel Cubby Speaker Replacement, Dissasemble the device: 步骤 1 中的图像 1,2 Sprout Channel Cubby Speaker Replacement, Dissasemble the device: 步骤 1 中的图像 2,2
      • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
      • It is easiest to start on the corners.
      添加评论
    1. Sprout Channel Cubby Speaker Replacement, Speaker: 步骤 2 中的图像 1,2 Sprout Channel Cubby Speaker Replacement, Speaker: 步骤 2 中的图像 2,2
      • While using the spatula, slowly get under the top part of the speaker. Then slowly move down the speaker to detach it from the device (there is a small amount of adhesive).
      询问修复机器人
      添加评论
    2. Sprout Channel Cubby Speaker Replacement: 步骤 3 中的图像 1,2 Sprout Channel Cubby Speaker Replacement: 步骤 3 中的图像 2,2
      • Remove black tape.
      • Disconnect the red and black wires which are soldered to the device. Make sure to not remove the wires that connect to the battery.
      • Replace the speaker.
      • Follow the steps in reverse order (be sure to solder the wires correctly) to install it.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
USF Tampa, Team 14-101, Meier Fall 2015 USF Tampa, Team 14-101, Meier Fall 2015 的会员
USFT-MEIER-F15S14G101
4 名成员
创作了12篇指南
2指南评论
Jasen, where can I purchase the replacement speaker for the Sprout?
william mulligan - 回复 分享
There is no way that I would want to take apart a new tablet to replaceor repair the speakers. Why not install it correctly the first time? Appears to be an ongoing issue.
Edreia Jones - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 33
总计 1,576
