跳转到主内容
加入维修社区 - 创建账户
Spin Master Boxer Remote Trigger Buttons Replacement
你所需要的
    1. Spin Master Boxer Remote Trigger Buttons Replacement, Remote Trigger Buttons: 步骤 1 中的图像 1,1
      • Lay the remote flat on your work space, with joysticks facing you.
      询问修复机器人
      添加评论
    2. Spin Master Boxer Remote Trigger Buttons Replacement: 步骤 2 中的图像 1,1
      • Remove both joysticks by gripping under circular knob and gently pulling towards you.
      • The joysticks should detach without much effort.
      询问修复机器人
      添加评论
    3. Spin Master Boxer Remote Trigger Buttons Replacement: 步骤 3 中的图像 1,1
      • Use the Phillips #00 Screwdriver to remove 4mm screw on the center battery panel.
      • Remove the batteries from the remote and set it to side.
      • Use the same screwdriver to remove all four 4mm screws on back panel.
      询问修复机器人
      添加评论
    4. Spin Master Boxer Remote Trigger Buttons Replacement: 步骤 4 中的图像 1,2 Spin Master Boxer Remote Trigger Buttons Replacement: 步骤 4 中的图像 2,2
      • Insert the Jimmy in between the top panel and the bottom panel.
      • Gently use the Jimmy to separate both plastic panels from each other.
      • Pull the panels apart and set bottom piece on workbench.
      询问修复机器人
      添加评论
    5. Spin Master Boxer Remote Trigger Buttons Replacement: 步骤 5 中的图像 1,2 Spin Master Boxer Remote Trigger Buttons Replacement: 步骤 5 中的图像 2,2
      • Pinch the trigger between index finger and thumb, and lift up, away from circuit board.
      • Inspect the square button attached to circuit board to ensure functionality. If there is an issue with connection, a new circuit boards may be required.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Lauren Roide
于04/16/19注册
769 声望
创作了5篇指南
团队
Cal Poly, Team S1-G1, Maness Spring 2019 Cal Poly, Team S1-G1, Maness Spring 2019 的会员
CPSU-MANESS-S19S1G1
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 16
过去 30 天: 43
总计 1,326
