跳转到主内容
加入维修社区 - 创建账户
Sony-BDP-SX1000 Battery Replacement
你所需要的
    1. 注意:步骤 1-2 源自标记为进行中的 指南。
      Sony-BDP-SX1000 Battery Replacement, How To Open The Device: 步骤 1 中的图像 1,2 Sony-BDP-SX1000 Battery Replacement, How To Open The Device: 步骤 1 中的图像 2,2
      • Flip the Sony BDP-SX1000 over so that the underside is facing up.
      • Remove the four 2mm Phillips #0 screws at the top of the device.
      • Remove the rest of the J0mm Phillips #0 screws from the device.
      询问修复机器人
      添加评论
    2. Sony-BDP-SX1000 Battery Replacement: 步骤 2 中的图像 1,2 Sony-BDP-SX1000 Battery Replacement: 步骤 2 中的图像 2,2
      • Take out the seals at the bottom and at the corners with edge of screwdriver. Remove the J0mm Phillips #0 screws under the seals.
      • Remove the back lid of the Sony BDP-SX1000 so that you can now see the inside of the device. The two lids are attached by two wires. The small wire on right side of the top lid goes on right side of bottom lid or on the black connector. The big wire on left side of the top lid goes on left side of the bottom lid or on white connector.
      询问修复机器人
      添加评论
    1. Sony-BDP-SX1000 Battery Replacement, Battery: 步骤 3 中的图像 1,2 Sony-BDP-SX1000 Battery Replacement, Battery: 步骤 3 中的图像 2,2
      • The battery can be found at the bottom of the device.
      • Remove the battery by removing the white connector.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
UC Davis, Team S4-G2, Lore Fall 2018 UC Davis, Team S4-G2, Lore Fall 2018 的会员
UCD-LORE-F18S4G2
3 名成员
创作了9篇指南
1指南评论
Any one know where to find replacement batteries?
ledude71 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 25
过去 30 天: 62
总计 2,016
