跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z2 Logic Board Replacement
你所需要的
视频概述
    1. Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: 步骤 1 中的图像 1,3 Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: 步骤 1 中的图像 2,3 Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: 步骤 1 中的图像 3,3
      • Switch off the phone.
      • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
      • Warm the Back Cover. You can use a hairdryer.
      • Be careful, the Back Cover is plastic.
      询问修复机器人
      添加评论
    2. Sony Xperia Z2 Logic Board Replacement: 步骤 2 中的图像 1,3 Sony Xperia Z2 Logic Board Replacement: 步骤 2 中的图像 2,3 Sony Xperia Z2 Logic Board Replacement: 步骤 2 中的图像 3,3
      • Use a small suction cup and plastic tools for separating the Rear panel.
      • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
      询问修复机器人
      添加评论
    3. Sony Xperia Z2 Logic Board Replacement: 步骤 3 中的图像 1,2 Sony Xperia Z2 Logic Board Replacement: 步骤 3 中的图像 2,2
      • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
      添加评论
    1. Sony Xperia Z2 Logic Board Replacement, Battery: 步骤 4 中的图像 1,3 Sony Xperia Z2 Logic Board Replacement, Battery: 步骤 4 中的图像 2,3 Sony Xperia Z2 Logic Board Replacement, Battery: 步骤 4 中的图像 3,3
      添加评论
    1. Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: 步骤 5 中的图像 1,3 Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: 步骤 5 中的图像 2,3 Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: 步骤 5 中的图像 3,3
      • Unscrew the screw and remove the Wi-Fi Antenna.
      添加评论
    1. Sony Xperia Z2 Logic Board Replacement, Logic Board: 步骤 6 中的图像 1,2 Sony Xperia Z2 Logic Board Replacement, Logic Board: 步骤 6 中的图像 2,2
      • Disconnect one by one:
      • Magnetic Charging Dock Flex Cable
      • Volume / Power Button and Microphone Flex Cable
      • Main Camera
      • Audio Jack and Light Sensor Flex cable
      • Coaxial Antenna Cable
      添加评论
    2. Sony Xperia Z2 Logic Board Replacement: 步骤 7 中的图像 1,3 Sony Xperia Z2 Logic Board Replacement: 步骤 7 中的图像 2,3 Sony Xperia Z2 Logic Board Replacement: 步骤 7 中的图像 3,3
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
19等其他人完成本指南。
ZFix
于12/09/13注册
197,378 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
334 名成员
创作了3,594篇指南
3指南评论
Hi
Do anyone knows where I can buy a logic board for Xperia Z2?
Johannes Stockinger - 回复 分享
https://www.ebay.com/sch/i.html?_from=R4...
or I bought there
https://ru.aliexpress.com/wholesale?catI...
be careful to find cheaper price and for your model D6503 or D6563…
Alexander - 回复 分享
Are you sure Phillips #00 is the correct size of screwdriver? I had difficulty getting one of the screws to turn (the screwdriver kept slipping), so I tried the other sizes in my iOpener Kit and found that the PH#000 seemed to fit them better, and that screw came straight out with it.
Edward Millen - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 48
总计 19,335
