跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z1 Compact Screen Replacement
你所需要的
  1. Sony Xperia Z1 Compact Screen Replacement, Apply heat: 步骤 1 中的图像 1,1
    • Apply heat to the edges.
    询问修复机器人
    添加评论
  2. Sony Xperia Z1 Compact Screen Replacement, Start prying: 步骤 2 中的图像 1,1
    • When the glue is warm slowly start prying from the top corner.
    询问修复机器人
    添加评论
  3. Sony Xperia Z1 Compact Screen Replacement, Add more heat if necessary: 步骤 3 中的图像 1,1
    • If the glue is cooled down heat more. Don't force it.
    询问修复机器人
    添加评论
  4. Sony Xperia Z1 Compact Screen Replacement, Cable: 步骤 4 中的图像 1,1
    • Remove the data cable from the phones body.
    询问修复机器人
    添加评论
  5. Sony Xperia Z1 Compact Screen Replacement, Testing new screen: 步骤 5 中的图像 1,1
    • Test if the new screen works properly.
    询问修复机器人
    添加评论
  6. Sony Xperia Z1 Compact Screen Replacement, The tape: 步骤 6 中的图像 1,1
    • If the screen works, remove the new screen and add the double sided tape
    询问修复机器人
    添加评论
  7. Sony Xperia Z1 Compact Screen Replacement, Connecting new screen: 步骤 7 中的图像 1,1
    • Connect the new screen to the phone.
    询问修复机器人
    添加评论
  8. Sony Xperia Z1 Compact Screen Replacement, Apply force: 步骤 8 中的图像 1,1
    • Now push town not to tight not to softly to the screen.
    • And that's it. You finished the screen replacement.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
30等其他人完成本指南。
jaanparker
于01/21/16注册
952 声望
撰写一个指南
5指南评论
There is a very good Youtube video of this. I think these are screenshots from it.
Andrew - 回复 分享
Good video! Help me too! Thanks
Clodoaldo Castro - 回复 分享
There is a thin, soft foam layer on the backside of the factory screen assembly, right behind the LCD backlight. This insulation foam is missing from most replacement screens. It can be peeled off relatively easily, but it will not stick easily onto the replacement LCD. I am not sure whether it is required at all, does anybody have experience and recommendations concerning this?
sinistre - 回复 分享
My lcd burn before use Heat gun! Very sad!
Use t7000 glue for glueing screen back down,sure way of it not lifting off
Marcus Roach - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 33
总计 18,239
