跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z1 Compact Motherboard Replacement
你所需要的
    1. Sony Xperia Z1 Compact Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Heat along the edges of the back cover using a heat gun to soften the glue.
      询问修复机器人
      添加评论
    2. Sony Xperia Z1 Compact Motherboard Replacement: 步骤 2 中的图像 1,1
      • Attach the small suction cup to the back cover near the bottom of the phone.
      • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
      询问修复机器人
      添加评论
    3. Sony Xperia Z1 Compact Motherboard Replacement: 步骤 3 中的图像 1,2 Sony Xperia Z1 Compact Motherboard Replacement: 步骤 3 中的图像 2,2
      • Move the spudger around the edge of the back cover to separate it from the black adhesive.
      • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
      询问修复机器人
      添加评论
    1. Sony Xperia Z1 Compact Motherboard Replacement, Battery: 步骤 4 中的图像 1,2 Sony Xperia Z1 Compact Motherboard Replacement, Battery: 步骤 4 中的图像 2,2
      • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
      询问修复机器人
      添加评论
    2. Sony Xperia Z1 Compact Motherboard Replacement: 步骤 5 中的图像 1,2 Sony Xperia Z1 Compact Motherboard Replacement: 步骤 5 中的图像 2,2
      • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
      添加评论
    3. Sony Xperia Z1 Compact Motherboard Replacement: 步骤 6 中的图像 1,1
      • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
      询问修复机器人
      添加评论
    4. Sony Xperia Z1 Compact Motherboard Replacement: 步骤 7 中的图像 1,1
      • Remove the battery from the device
      询问修复机器人
      添加评论
    1. Sony Xperia Z1 Compact Motherboard Replacement, External Speaker: 步骤 8 中的图像 1,2 Sony Xperia Z1 Compact Motherboard Replacement, External Speaker: 步骤 8 中的图像 2,2
      • Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
      询问修复机器人
      添加评论
    2. Sony Xperia Z1 Compact Motherboard Replacement: 步骤 9 中的图像 1,3 Sony Xperia Z1 Compact Motherboard Replacement: 步骤 9 中的图像 2,3 Sony Xperia Z1 Compact Motherboard Replacement: 步骤 9 中的图像 3,3
      • Wedge the plastic opening tool under the back frame. Move the plastic opening tool around the entire frame to separate it from the adhesive.
      询问修复机器人
      添加评论
    3. Sony Xperia Z1 Compact Motherboard Replacement: 步骤 10 中的图像 1,1
      • Remove the back frame.
      询问修复机器人
      添加评论
    4. Sony Xperia Z1 Compact Motherboard Replacement: 步骤 11 中的图像 1,2 Sony Xperia Z1 Compact Motherboard Replacement: 步骤 11 中的图像 2,2
      • Wedge the spudger underneath the external speaker. Pull up on the external speaker using the spudger.
      询问修复机器人
      添加评论
    5. Sony Xperia Z1 Compact Motherboard Replacement: 步骤 12 中的图像 1,2 Sony Xperia Z1 Compact Motherboard Replacement: 步骤 12 中的图像 2,2
      • Remove the external speaker.
      询问修复机器人
      添加评论
    1. Sony Xperia Z1 Compact Motherboard Replacement, Motherboard: 步骤 13 中的图像 1,2 Sony Xperia Z1 Compact Motherboard Replacement, Motherboard: 步骤 13 中的图像 2,2
      • Remove the square rubber gasket from the camera using the plastic spudger.
      询问修复机器人
      添加评论
    2. Sony Xperia Z1 Compact Motherboard Replacement: 步骤 14 中的图像 1,2 Sony Xperia Z1 Compact Motherboard Replacement: 步骤 14 中的图像 2,2
      • Remove the black plastic corner still holding in the motherboard.
      询问修复机器人
      添加评论
    3. Sony Xperia Z1 Compact Motherboard Replacement: 步骤 15 中的图像 1,3 Sony Xperia Z1 Compact Motherboard Replacement: 步骤 15 中的图像 2,3 Sony Xperia Z1 Compact Motherboard Replacement: 步骤 15 中的图像 3,3
      • Carefully pry up on the four sides of the motherboard using the plastic spudger til it separates from the base of the phone.
      询问修复机器人
      添加评论
    4. Sony Xperia Z1 Compact Motherboard Replacement: 步骤 16 中的图像 1,3 Sony Xperia Z1 Compact Motherboard Replacement: 步骤 16 中的图像 2,3 Sony Xperia Z1 Compact Motherboard Replacement: 步骤 16 中的图像 3,3
      • Remove the motherboard from the device.
      • There may be a small yellow adhesive underneath the motherboard still holding it in. Slide the tip of the spudger through it to sever it.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
1指南评论
hi
Recently i brought Xperia Z1 now i am facing charging problem.
i already change new to battery but it is charging 75 % only.
after charging 75% my phone screen continually on and off
please let me know how can i fix this problem.
malinduariyasingha - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 43
总计 4,192
