跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z1 Compact Battery Replacement
你所需要的
    1. Sony Xperia Z1 Compact Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Heat along the edges of the back cover using a heat gun to soften the glue.
      询问修复机器人
      添加评论
    2. Sony Xperia Z1 Compact Battery Replacement: 步骤 2 中的图像 1,1
      • Attach the small suction cup to the back cover near the bottom of the phone.
      • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
      询问修复机器人
      添加评论
    3. Sony Xperia Z1 Compact Battery Replacement: 步骤 3 中的图像 1,2 Sony Xperia Z1 Compact Battery Replacement: 步骤 3 中的图像 2,2
      • Move the spudger around the edge of the back cover to separate it from the black adhesive.
      • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
      询问修复机器人
      添加评论
    1. Sony Xperia Z1 Compact Battery Replacement, Battery: 步骤 4 中的图像 1,2 Sony Xperia Z1 Compact Battery Replacement, Battery: 步骤 4 中的图像 2,2
      • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
      询问修复机器人
      添加评论
    2. Sony Xperia Z1 Compact Battery Replacement: 步骤 5 中的图像 1,2 Sony Xperia Z1 Compact Battery Replacement: 步骤 5 中的图像 2,2
      • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
      添加评论
    3. Sony Xperia Z1 Compact Battery Replacement: 步骤 6 中的图像 1,1
      • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
      询问修复机器人
      添加评论
    4. Sony Xperia Z1 Compact Battery Replacement: 步骤 7 中的图像 1,1
      • Remove the battery from the device
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
12等其他人完成本指南。
kinan badr
于09/21/17注册
386 声望
撰写一个指南
团队
3指南评论
is there any reliable source for good replacement battery purchase?
Upendra Gandhi - 回复 分享
What is the Ariel stuck on the battery ?
Tony - 回复 分享
NFC Antenna. You should carefully transplant it to new battery, in case your new battery is without one (what is the case for most 3rd party batteries available)
Peter Pepo - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 43
总计 12,518
