跳转到主内容
加入维修社区 - 创建账户
Sony Xperia XZ2 LCD Screen Replacement
你所需要的
  1. Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
    • The phone gets very hot and can hurt the user handling it.
    询问修复机器人
    添加评论
  2. Sony Xperia XZ2 LCD Screen Replacement: 步骤 2 中的图像 1,3 Sony Xperia XZ2 LCD Screen Replacement: 步骤 2 中的图像 2,3 Sony Xperia XZ2 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
    • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
    添加评论
  3. Sony Xperia XZ2 LCD Screen Replacement: 步骤 3 中的图像 1,2 Sony Xperia XZ2 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
    • The screen is still attached by a connector, so do not pull the pieces apart.
    询问修复机器人
    添加评论
  4. Sony Xperia XZ2 LCD Screen Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    $3.99
    • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
    添加评论
  5. Sony Xperia XZ2 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Gently remove the connector by using a spudger to pop it off.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
9等其他人完成本指南。
团队
Cal Poly, Team S19-G5, White Winter 2019 Cal Poly, Team S19-G5, White Winter 2019 的会员
CPSU-WHITE-W19S19G5
4 名成员
创作了20篇指南
4指南评论
Worked perfectly fine for my xz2 compact
Maria Schrenk - 回复 分享
Hi, someone knows how to glue it back. I read that if I use B-6000 glue it will damage my screen.
Diego Covenas - 回复 分享
Double-sided adhesive should do the trick. For example 2mm Universal 3M Adhesive Tape should be preferred to glue.
Célestin Taramarcaz - 回复 分享
The XZ2 Compact has the same screen connector+clip.
My screen came without the upper speaker grille (plastic+fabric). When I tried to remove the glue from the old one the fabric got delaminated from the plastic. Tip: Check if the grille is in place before gluing back!
Dimitrios Josef Moustos - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 98
总计 11,782
