简介
To complete this guide you will need to disassemble your device and use tweezers to extract the SIM card reader.
The battery should be removed before working on the phone internals.
你所需要的
You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
在这个步骤中使用的工具:Tweezers$4.99
Using the tweezers remove the clip located at the top of the phone. It should snap right off without too much pressure.
Using the tweezers lift the plate out of the clamps, from left to right.
Then remove the whole plate off the phone.
5等其他人完成本指南。
