跳转到主内容
加入维修社区 - 创建账户
Sony XPERIA Tablet Z Micro USB Port Replacement
你所需要的
    1. Sony XPERIA Tablet Z Micro USB Port Replacement, Micro USB Port: 步骤 1 中的图像 1,3 Sony XPERIA Tablet Z Micro USB Port Replacement, Micro USB Port: 步骤 1 中的图像 2,3 Sony XPERIA Tablet Z Micro USB Port Replacement, Micro USB Port: 步骤 1 中的图像 3,3
      在这个步骤中使用的工具:
      • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
      • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
      • Remove cover
      添加评论
    2. Sony XPERIA Tablet Z Micro USB Port Replacement: 步骤 2 中的图像 1,3 Sony XPERIA Tablet Z Micro USB Port Replacement: 步骤 2 中的图像 2,3 Sony XPERIA Tablet Z Micro USB Port Replacement: 步骤 2 中的图像 3,3
      • Located in the bottom left of the device you will remove the two screws holding the metal plate on the USB port.
      • Remove metal plate
      • Remove plastic securing the USB port.
      询问修复机器人
      添加评论
    3. Sony XPERIA Tablet Z Micro USB Port Replacement: 步骤 3 中的图像 1,3 Sony XPERIA Tablet Z Micro USB Port Replacement: 步骤 3 中的图像 2,3 Sony XPERIA Tablet Z Micro USB Port Replacement: 步骤 3 中的图像 3,3
      • Remove screw with screw diver and lift metal plate with tweezers.
      • Pick up left end of the electrical tape
      • Lift up to remove USB plug from the mounting location.
      添加评论
结论
取消:我没有完成这个指南。
30等其他人完成本指南。
Martin Luna
于09/24/14注册
1,873 声望
创作了5篇指南
团队
USF Tampa, Team 15-6, Remmell Fall 2014 USF Tampa, Team 15-6, Remmell Fall 2014 的会员
USFT-REMMELL-F14S15G6
3 名成员
创作了7篇指南
14指南评论
Thank you! easy and straight forward.
Any suggestions on an adhesive for the back cover?
Heath240 - 回复 分享
I was able to replace the usb port but my tablet still wont charge or be recognized as usb when connected to PC. What can this be? Any idea? Please I need help.
esteeizaola - 回复 分享
I also replace charging port with same result, I was not able to find a solution online so until I can find a magnetic docking station for sale I have bypassed the charging port and connected my usb direct to the battery with 100% result.
My tablet never goes outdoors so the waterproof covers is not needed, bloody well good job as there now is a usb cable poking out the cover and sealed closed with electrial type
Higgs - 回复 分享
I was able to replace my connector after much difficulty (the part I received wasn't the exact size so I had to cut a little bit and force a lot!). I worked great... For approx. 2 weeks. Now I'm back to square one. I was wondering if it would be possible to fabricate a magnetic dock (or similar), since the official one seems impossible to find?
Lynx - 回复 分享
I replaced the usb port and had the same problem as esteeizola because my battery was completely drained. (IMHO Sony has a design fault with their USB ports. They are rubish. If you get more than 200 plug/unplug operations out of a Sony USB you are very lucky).
What happened was that USB drew 4 to 5 milli-amps for about 10 to 12 amps. During this time the red led was lit but the device remained dead. Finally, USB started drawing a normally charging current (a very pathetic 300 milli-amps from what I can tell.) And the device came to life say the battery was 2% charged.
I don't what the reason is for this behavior but it certainly is very confusing and frustrating,
Peter Moy - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 62
总计 31,770
