跳转到主内容
Sony Vaio VPCCW17FX Speakers Replacement
你所需要的
  1. Sony Vaio VPCCW17FX Speakers Replacement, Speakers: 步骤 1 中的图像 1,1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Speakers Replacement: 步骤 2 中的图像 1,1
    • Slide the two latches towards the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Speakers Replacement: 步骤 3 中的图像 1,2 Sony Vaio VPCCW17FX Speakers Replacement: 步骤 3 中的图像 2,2
    • Use fingernail or plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Speakers Replacement: 步骤 4 中的图像 1,2 Sony Vaio VPCCW17FX Speakers Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #0 screwdriver to remove the two screws (Length: 7.7 mm) of the Hard Drive cover and place the cover to the side.
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) from the RAM cover and place it to the side.
  5. Sony Vaio VPCCW17FX Speakers Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove all twelve screws (Length: 7.7 mm) that hold the bottom cover.
  6. Sony Vaio VPCCW17FX Speakers Replacement: 步骤 6 中的图像 1,1
    • Lift and remove the back cover.
  7. Sony Vaio VPCCW17FX Speakers Replacement: 步骤 7 中的图像 1,2 Sony Vaio VPCCW17FX Speakers Replacement: 步骤 7 中的图像 2,2
    • Locate the fan and use a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold it in place.
    • Lift the fan and move it out of the way.
  8. Sony Vaio VPCCW17FX Speakers Replacement: 步骤 8 中的图像 1,2 Sony Vaio VPCCW17FX Speakers Replacement: 步骤 8 中的图像 2,2
    • Begin removing the four screws with a Phillips #0 screwdriver (Length: 7.7 mm) from the back cover.
    • Place the cover out of the way.
    • Be careful to not pull any wires out while moving the cover.
  9. Sony Vaio VPCCW17FX Speakers Replacement: 步骤 9 中的图像 1,3 Sony Vaio VPCCW17FX Speakers Replacement: 步骤 9 中的图像 2,3 Sony Vaio VPCCW17FX Speakers Replacement: 步骤 9 中的图像 3,3
    • Using a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold the speaker in place.
    • Follow the wire until you find the ribbon cable that holds the wires and pull straight out of the connect to remove it.
    • You are now free to replace the speakers.
    • There are two speakers so be sure to repeat the same steps for the second speaker.
结论
Brianna Rukes
于03/21/17注册
101 声望
撰写一个指南
团队
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 的会员
TTU-BENNETT-S17S8G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 486
