跳转到主内容
加入维修社区 - 创建账户
Sony RM-LVR1 LCD Screen Replacement
你所需要的
    1. Sony RM-LVR1 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
      • If the screws strips or is previously stripped, refer to the stripped screw repair guide.
      询问修复机器人
      添加评论
    2. Sony RM-LVR1 LCD Screen Replacement: 步骤 2 中的图像 1,1
      • Battery is the rectangular and silver object in the center of device.
      • Remove battery with finger by prying at the rear.
      • If unable to remove battery, pry out using spudger.
      询问修复机器人
      添加评论
    1. Sony RM-LVR1 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 1,2 Sony RM-LVR1 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 2,2
      • Unscrew the 3 (three) screws holding the bracket in place.
      • Then remove the bracket by prying one end up.
      • Do not rip the ribbon cable connecting the bracket to the motherboard.
      询问修复机器人
      添加评论
    2. Sony RM-LVR1 LCD Screen Replacement: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      • With tweezers, unplug the ribbon cable from the white connector.
      询问修复机器人
      添加评论
    3. Sony RM-LVR1 LCD Screen Replacement: 步骤 5 中的图像 1,1
      • Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
      询问修复机器人
      添加评论
    4. Sony RM-LVR1 LCD Screen Replacement: 步骤 6 中的图像 1,1
      • Gently push out on these two clips holding the LCD to the motherboard
      • Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
      • There is a ribbon cable underneath the LCD connecting it to the motherboard. Avoid sharp, sudden movements to prevent it from being damged
      添加评论
    5. Sony RM-LVR1 LCD Screen Replacement: 步骤 7 中的图像 1,2 Sony RM-LVR1 LCD Screen Replacement: 步骤 7 中的图像 2,2
      • Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
      询问修复机器人
      添加评论
    6. Sony RM-LVR1 LCD Screen Replacement: 步骤 8 中的图像 1,1
      • Remove the screen from the motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
4指南评论
здорово!
подскажите где купить дисплей?, или его маркировку?. на дисплее ничего не написано, не могу найти.
Александр - 回复 分享
Hi
I cant find an replacement lcd.
Could anybody help me where to get one?
Cheers
Sven
Sven van Bellen - 回复 分享
any link to the replacement LCD please?
Bart Ptachowski - 回复 分享
Hi .
search : HD 170 LCD Drift aliexp****
i think it will do the job .
cheers
ruigyl - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 26
总计 1,022
