跳转到主内容
加入维修社区 - 创建账户
Sony Pulse Elite Edition Battery Replacement
你所需要的
  1. Sony Pulse Elite Edition Battery Replacement, Identifying Earpiece: 步骤 1 中的图像 1,1
    • Locate the left side designation on the headband-earpiece junction.
    • The battery is in the right earpiece.
    • The motherboard is in the left earpiece.
    询问修复机器人
    添加评论
  2. Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: 步骤 2 中的图像 1,2 Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: 步骤 2 中的图像 2,2
    • Gently pull around the perimeter of the left ear cushion until it comes off.
    添加评论
  3. Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: 步骤 3 中的图像 1,2 Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: 步骤 3 中的图像 2,2
    • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
    • Gently pull the outer ear rim off of the headset assembly.
    • Harsh removal may cause permanent damage to the speaker wires.
    询问修复机器人
    添加评论
  4. Sony Pulse Elite Edition Battery Replacement, Remove Speaker Housing: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, gently pry the red and black speaker wires from the attached socket.
    询问修复机器人
    添加评论
  5. Sony Pulse Elite Edition Battery Replacement, Remove Battery: 步骤 5 中的图像 1,2 Sony Pulse Elite Edition Battery Replacement, Remove Battery: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Lift up battery and disconnect wires using tweezers.
    • Use a new battery for reconstruction.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
8指南评论
Where can I buy the replacement battery for this?
Pretty hard to find...
francisklalumiere - 回复 分享
Replacement batteries can be found by googling "SP70C battery". It is a Lithium battery with 900mAh and a 3.7v output. AliExpress shows them for $11 including shipping.
David McAndrews - 回复 分享
Can I mod and replace the battery with a bigger one with no white connection, just positive and negative? Thanks!
marit - 回复 分享
Thank you so much for this guide. I got a 1000mAh batter from Amazon for 10 dollars. It lasts way longer and was extremely easy to install. Very thankful for this. Thanks!
sharku19z - 回复 分享
i just attempted... the connector to the battery just pulled off. NOTE: Pull up from PCB not out. The connector sets down into it.
Garrett Parmenter - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 34
过去 30 天: 162
总计 14,064
