跳转到主内容
加入维修社区 - 创建账户
Sony PlayStation Camera Microphone Array Replacement
你所需要的
  1. Sony PlayStation Camera Microphone Array Replacement, Microphone Array: 步骤 1 中的图像 1,2 Sony PlayStation Camera Microphone Array Replacement, Microphone Array: 步骤 1 中的图像 2,2
    • Separate the camera from the camera stand to gain access to the bottom of the camera.
    询问修复机器人
    添加评论
  2. Sony PlayStation Camera Microphone Array Replacement: 步骤 2 中的图像 1,2 Sony PlayStation Camera Microphone Array Replacement: 步骤 2 中的图像 2,2
    • With the PH000 sized screwdriver, remove the two 6.5mm Phillips #000 screws located under the stand connection point, where the cable enters the case.
    询问修复机器人
    添加评论
  3. Sony PlayStation Camera Microphone Array Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, remove the cap holding the cable grommet in place.
    询问修复机器人
    添加评论
  4. Sony PlayStation Camera Microphone Array Replacement: 步骤 4 中的图像 1,1
    • Using the tweezers, remove both poly-carbonate lens coverplates.
    • Lift the coverplates slowly, to ensure they do not crack, or break.
    询问修复机器人
    添加评论
  5. Sony PlayStation Camera Microphone Array Replacement: 步骤 5 中的图像 1,2 Sony PlayStation Camera Microphone Array Replacement: 步骤 5 中的图像 2,2
    • Using the PH0 sized screwdriver, remove two 3.2mm Phillips #0 screws, located under the coverplates.
    询问修复机器人
    添加评论
  6. Sony PlayStation Camera Microphone Array Replacement: 步骤 6 中的图像 1,1
    • Using extreme care, separate the front of the case, from the back with a metal spudger, or pry tool. The case will scratch easily.
    • The case joints can be hard to spot. They appear as a very fine line in the plastic. Start with light pressure until the seam parts, allowing the pry tool to work.
    询问修复机器人
    添加评论
  7. Sony PlayStation Camera Microphone Array Replacement: 步骤 7 中的图像 1,2 Sony PlayStation Camera Microphone Array Replacement: 步骤 7 中的图像 2,2
    • Using the PH0 sized screwdriver, remove the four 4.5mm Phillips #0 screws securing the circuit assembly to the device housing.
    询问修复机器人
    添加评论
  8. Sony PlayStation Camera Microphone Array Replacement: 步骤 8 中的图像 1,3 Sony PlayStation Camera Microphone Array Replacement: 步骤 8 中的图像 2,3 Sony PlayStation Camera Microphone Array Replacement: 步骤 8 中的图像 3,3
    • Lift the motherboard and frame from the plastic housing.
    • Disconnect the camera cable from the motherboard.
    询问修复机器人
    添加评论
  9. Sony PlayStation Camera Microphone Array Replacement: 步骤 9 中的图像 1,2 Sony PlayStation Camera Microphone Array Replacement: 步骤 9 中的图像 2,2
    • Using the PH0 sized screwdriver, remove the six 4.2mm Phillips #0 screws securing the motherboard to the metal frame.
    询问修复机器人
    添加评论
  10. Sony PlayStation Camera Microphone Array Replacement: 步骤 10 中的图像 1,2 Sony PlayStation Camera Microphone Array Replacement: 步骤 10 中的图像 2,2
    • Using a plastic opening tool, disconnect the microphone array connector from the motherboard.
    询问修复机器人
    添加评论
  11. Sony PlayStation Camera Microphone Array Replacement: 步骤 11 中的图像 1,3 Sony PlayStation Camera Microphone Array Replacement: 步骤 11 中的图像 2,3 Sony PlayStation Camera Microphone Array Replacement: 步骤 11 中的图像 3,3
    • Using fine point tweezers, grab hold of each microphone, one at a time, and lift from the plastic frame.
    • Using care to not damage the wires, remove microphone array from the retaining tabs on the plastic frame.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Joshua Gates
于02/15/17注册
268 声望
创作了2篇指南
团队
USF Tampa, Team 5-5, Passmore Spring 2017 USF Tampa, Team 5-5, Passmore Spring 2017 的会员
USFT-PASSMORE-S17S5G5
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 54
总计 7,810
