跳转到主内容
加入维修社区 - 创建账户
Sony PlayStation 3D Display Control Buttons Replacement
你所需要的
    1. Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: 步骤 1 中的图像 1,2 Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: 步骤 1 中的图像 2,2
      • Remove the base by pushing in the button and sliding out the unit.
      添加评论
    2. Sony PlayStation 3D Display Control Buttons Replacement: 步骤 2 中的图像 1,3 Sony PlayStation 3D Display Control Buttons Replacement: 步骤 2 中的图像 2,3 Sony PlayStation 3D Display Control Buttons Replacement: 步骤 2 中的图像 3,3
      • Remove USB port cover from back plate with a metal spudger.
      • This will prevent the cover from falling under the back plate once it is removed.
      询问修复机器人
      添加评论
    3. Sony PlayStation 3D Display Control Buttons Replacement: 步骤 3 中的图像 1,2 Sony PlayStation 3D Display Control Buttons Replacement: 步骤 3 中的图像 2,2
      • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
      • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
      • These screws have different threads and need to be kept separate.
      询问修复机器人
      添加评论
    4. Sony PlayStation 3D Display Control Buttons Replacement: 步骤 4 中的图像 1,3 Sony PlayStation 3D Display Control Buttons Replacement: 步骤 4 中的图像 2,3 Sony PlayStation 3D Display Control Buttons Replacement: 步骤 4 中的图像 3,3
      • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
      • Be gentle to avoid breaking the plastic clips which hold the plate.
      • Once separated the plate easily lifts off.
      询问修复机器人
      添加评论
    1. Sony PlayStation 3D Display Control Buttons Replacement, Control Buttons: 步骤 5 中的图像 1,1
      • With the Phillips #01 screwdriver, remove the two 5 mm length x 7 mm head screws from the top and bottom of the control button bar.
      询问修复机器人
      添加评论
    2. Sony PlayStation 3D Display Control Buttons Replacement: 步骤 6 中的图像 1,2 Sony PlayStation 3D Display Control Buttons Replacement: 步骤 6 中的图像 2,2
      • Detach the control button bar by depressing the small white tab that connects the bar to its wires.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 12-16, Maness Fall 2015 Cal Poly, Team 12-16, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G16
4 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 29
总计 1,004
