跳转到主内容
加入维修社区 - 创建账户
Sony NEX-7 Viewfinder Replacement
你所需要的
    1. Sony NEX-7 Viewfinder Replacement, Battery: 步骤 1 中的图像 1,2 Sony NEX-7 Viewfinder Replacement, Battery: 步骤 1 中的图像 2,2
      • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
      • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
      询问修复机器人
      添加评论
    2. Sony NEX-7 Viewfinder Replacement: 步骤 2 中的图像 1,1
      • Flip the camera over such that the power switch points down.
      • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
      询问修复机器人
      添加评论
    3. Sony NEX-7 Viewfinder Replacement: 步骤 3 中的图像 1,1
      • With the battery door open, push the blue lever in the battery compartment to release the battery.
      询问修复机器人
      添加评论
    1. Sony NEX-7 Viewfinder Replacement, SD card: 步骤 4 中的图像 1,1
      • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
      • Pull the card out with your fingers.
      询问修复机器人
      添加评论
    1. Sony NEX-7 Viewfinder Replacement, Lens: 步骤 5 中的图像 1,2 Sony NEX-7 Viewfinder Replacement, Lens: 步骤 5 中的图像 2,2
      • First, turn the camera upside down.
      • Press the button located next to silver lens mount and rotate the lens counterclockwise.
      • Pull the lens away from the camera body.
      • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
      询问修复机器人
      添加评论
    1. Sony NEX-7 Viewfinder Replacement, Top and Back Shell: 步骤 6 中的图像 1,1
      • Start by removing the two 5/32" #00 screws on the bottom of the camera using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    2. Sony NEX-7 Viewfinder Replacement: 步骤 7 中的图像 1,2 Sony NEX-7 Viewfinder Replacement: 步骤 7 中的图像 2,2
      • Remove the 5/32" #00 screw at the top of the compartment using the Phillips #00 screwdriver.
      • Remove the two 5/32" #00 screws from inside the compartment using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    3. Sony NEX-7 Viewfinder Replacement: 步骤 8 中的图像 1,2 Sony NEX-7 Viewfinder Replacement: 步骤 8 中的图像 2,2
      • Close the battery door by pushing it down until it latches shut.
      询问修复机器人
      添加评论
    4. Sony NEX-7 Viewfinder Replacement: 步骤 9 中的图像 1,1
      • Looking at the left side of the camera, lift open the door that has 'HDMI' written on it.
      • Remove the two visible 5/32" #00 screws using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    5. Sony NEX-7 Viewfinder Replacement: 步骤 10 中的图像 1,3 Sony NEX-7 Viewfinder Replacement: 步骤 10 中的图像 2,3 Sony NEX-7 Viewfinder Replacement: 步骤 10 中的图像 3,3
      • Looking at the back of the camera, press the button with a lightning bolt on it to pop the flash open.
      • Remove the three 5/32" screws from within the flash compartment using the Phillips #00 screwdriver.
      • Close the flash compartment.
      询问修复机器人
      添加评论
    6. Sony NEX-7 Viewfinder Replacement: 步骤 11 中的图像 1,1
      • The top of the camera is attached by three wires and a ribbon cable. Remove the top slowly and gently!
      • Lift the top of the camera off of the body.
      • Let the top hang to the side so you have room to work with the components inside the device.
      询问修复机器人
      添加评论
    7. Sony NEX-7 Viewfinder Replacement: 步骤 12 中的图像 1,1
      在这个步骤中使用的工具:
      • Using tweezers or your fingers, gently remove the blue ribbon cable from the port.
      询问修复机器人
      添加评论
    8. Sony NEX-7 Viewfinder Replacement: 步骤 13 中的图像 1,2 Sony NEX-7 Viewfinder Replacement: 步骤 13 中的图像 2,2
      • Place the tips of your tweezers on either side of the red jack.
      • Gently pull the red plug out of the jack.
      • Repeat those steps for the yellow jack and plug.
      • Now that the top is free, place it aside for later.
      询问修复机器人
      添加评论
    9. Sony NEX-7 Viewfinder Replacement: 步骤 14 中的图像 1,1
      • Lift the LCD screen with your fingers such that the screen is bent slightly away from the camera.
      询问修复机器人
      添加评论
    10. Sony NEX-7 Viewfinder Replacement: 步骤 15 中的图像 1,3 Sony NEX-7 Viewfinder Replacement: 步骤 15 中的图像 2,3 Sony NEX-7 Viewfinder Replacement: 步骤 15 中的图像 3,3
      • Starting at the bottom, gently pry the back panel away from the body of the camera using your fingers.
      • Once the back panel is free from the body, rotate the camera such that back is facing you and pull the back panel past the screen by rotating it to fit around the screen.
      • The back panel will be easier to take off if the LCD screen has been extended away from the camera by about 60 degrees.
      • Set the back panel aside.
      询问修复机器人
      添加评论
    1. Sony NEX-7 Viewfinder Replacement, LCD Assembly: 步骤 16 中的图像 1,1
      • Remove the two 3/32" #00 screws located next to the viewfinder using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    2. Sony NEX-7 Viewfinder Replacement: 步骤 17 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove the two screws from the right side of the camera below the D ring:
      • The 5/32" upper screw
      • The 3/32" lower screw
      添加评论
    3. Sony NEX-7 Viewfinder Replacement: 步骤 18 中的图像 1,1
      • Remove two more 3/32" #00 screws from the bottom of the camera using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    4. Sony NEX-7 Viewfinder Replacement: 步骤 19 中的图像 1,1
      • Remove two more 3/32" #00 screws from the metal bracket on the left side of the camera using the Phillips #00 screwdriver.
      添加评论
    5. Sony NEX-7 Viewfinder Replacement: 步骤 20 中的图像 1,1
      在这个步骤中使用的工具:
      • Unplug the orange ribbon cable on the top right of the camera next to the metal bracket by applying tweezers to the tabs on either side of the plug.
      询问修复机器人
      添加评论
    6. Sony NEX-7 Viewfinder Replacement: 步骤 21 中的图像 1,1
      • Before pulling off the assembly, fold the rightmost tab of the flexible circuit board away from the metal bracket.
      询问修复机器人
      添加评论
    7. Sony NEX-7 Viewfinder Replacement: 步骤 22 中的图像 1,2 Sony NEX-7 Viewfinder Replacement: 步骤 22 中的图像 2,2
      • The LCD assembly is attached with a concealed ribbon cable, so be gentle when you remove it.
      • The D ring brackets on either side are not attached, only held in mechanically. Once the LCD assembly starts to come out, they will detach.
      • Pull on the D rings on either side of the camera to start removing the assembly.
      • Once the brackets are cleared from black shell, take them off and set them aside.
      • Continue to remove the screen assembly.
      询问修复机器人
      添加评论
    8. Sony NEX-7 Viewfinder Replacement: 步骤 23 中的图像 1,1
      • With the camera face down, move the assembly away from you to get a clear view of the wide ribbon cable.
      • Unplug the cable by applying tweezers to the tabs on either side of the plug.
      • Set the LCD assembly aside.
      询问修复机器人
      添加评论
    1. Sony NEX-7 Viewfinder Replacement, Viewfinder: 步骤 24 中的图像 1,1
      在这个步骤中使用的工具:
      • Using the tweezers, unhook the flexible circuit board from the metal tab on the right of the viewfinder by rotating it to the left.
      询问修复机器人
      添加评论
    2. Sony NEX-7 Viewfinder Replacement: 步骤 25 中的图像 1,1
      • Remove the 5/32" #00 screw next to the back right of the viewfinder using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    3. Sony NEX-7 Viewfinder Replacement: 步骤 26 中的图像 1,1
      • Using the tweezers lift the black piece of tape from the circuit board below the viewfinder.
      询问修复机器人
      添加评论
    4. Sony NEX-7 Viewfinder Replacement: 步骤 27 中的图像 1,1
      • Be gentle when removing the viewfinder because there is an orange ribbon cable connected to the body.
      • Use your fingers to lift the viewfinder from the body.
      询问修复机器人
      添加评论
    5. Sony NEX-7 Viewfinder Replacement: 步骤 28 中的图像 1,2 Sony NEX-7 Viewfinder Replacement: 步骤 28 中的图像 2,2
      • Use the tweezers to lift the black switch on the white receptacle just below the viewfinder. If properly opened, the ribbon cable will remove with very little force.
      询问修复机器人
      添加评论
    6. Sony NEX-7 Viewfinder Replacement: 步骤 29 中的图像 1,1
      • Use your fingers to remove the viewfinder from the camera body.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
Jay Miley
于04/22/14注册
5,462 声望
创作了13篇指南
团队
Cal Poly, Team 10-55, Amido Spring 2014 Cal Poly, Team 10-55, Amido Spring 2014 的会员
CPSU-AMIDO-S14S10G55
4 名成员
创作了81篇指南
4指南评论
Hello
thank you for this tutorial, can you tell me or buy a replacement viewfinder?
lbasile - 回复 分享
ขอบคุณมากสำหรับการแบ่งปันความรู้ ผมเชื่อว่าบทความของคุณจะเป็นประโยชน์มากมายต่อผู้ใช้กล้อง Sony
hs3lri - 回复 分享
A very handy set of instructions to have for working on an Next. Someone forced the top cover off the flash/strobe assembly of my Nex7 with their fingernail instead of using the push button. Consequently they damaged the black plastic top cover and broke the small coil spring that keeps the flash/strobe lense pointing forward. Are there any guides to help me remove the damaged assembly in order to fit an OEM replacement assembly? I reside in the UK, and the main Sony repair centre informs me that they can't obtain a new strobe/flash assembly. Does anybody know where I could obtain an OEM black top assembly? Are there any high quality direct replacement aftermarket compatible ones (I'm sure the Sony part is manufactured by a supplier to Sony for assembly of the camera) that can be recommended to fit the Nex 7?
Regards,
Sam Ellis
(Scotland, UK)
Sam Ellis - 回复 分享
Hi, i want to buy nex7 viewfinder. Where can i find it? Sorry by me english
Nano Lopez - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 63
总计 7,317
