跳转到主内容
Sony KDF-E60A20 Lamp Replacement
你所需要的
  1. Sony KDF-E60A20 Lamp Replacement, Lamp: 步骤 1 中的图像 1,3 Sony KDF-E60A20 Lamp Replacement, Lamp: 步骤 1 中的图像 2,3 Sony KDF-E60A20 Lamp Replacement, Lamp: 步骤 1 中的图像 3,3
    • Remove the two thumb screws.
  2. Sony KDF-E60A20 Lamp Replacement: 步骤 2 中的图像 1,3 Sony KDF-E60A20 Lamp Replacement: 步骤 2 中的图像 2,3 Sony KDF-E60A20 Lamp Replacement: 步骤 2 中的图像 3,3
    • With both thumb screws removed, the front bezel can now be easily pulled off. It is only held in place by three magnets.
    • With the bezel out of the way, there will be a small cover held in place by a crossbar and a thumb screw. Loosen the thumb screw and fold the bar out of the way.
    • The back of the lamp housing is now visible.
  3. Sony KDF-E60A20 Lamp Replacement: 步骤 3 中的图像 1,3 Sony KDF-E60A20 Lamp Replacement: 步骤 3 中的图像 2,3 Sony KDF-E60A20 Lamp Replacement: 步骤 3 中的图像 3,3
    • Loosen the 3mm Allen bolt. It will not come out of the lamp housing, but will loosen it to remove the lamp housing from the TV.
    • With the Allen bolt loose, pull the lamp houing slightly back and down,
    • this will remove the lamp in its housing.
  4. Sony KDF-E60A20 Lamp Replacement: 步骤 4 中的图像 1,3 Sony KDF-E60A20 Lamp Replacement: 步骤 4 中的图像 2,3 Sony KDF-E60A20 Lamp Replacement: 步骤 4 中的图像 3,3
    • Here is the old lamp and housing.
    • For the replacement, a complete lamp and housing was chosen. The lamp is individually available. There was not a big difference in cost, to justify the additional steps of replacing the lamp housing.
    • Install the new lamp and housing
  5. Sony KDF-E60A20 Lamp Replacement: 步骤 5 中的图像 1,1
    • Result of this $32 repair is a bright fully functioning TV
结论
13等其他人完成本指南。
oldturkey03
于09/29/10注册
811,549 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
45 名成员
创作了700篇指南
17条评论
Where did you purchase this bulb for $32?
Wendy Watson - 回复
Mine worked 4 3 hours then stayed off.
Love machine Guaranteed -
I ordered a replacement housing with new bulb in it and with shipping it was 35. Ordered it thru Sears online and they sent it out next day air. It took five min to swap out
Joker - 回复
Thanks a lot. You saved me money
Alexander Ritchie - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 31
总计 25,325
