简介
If your Sony ICF-C1T alarm clock/radio is having issues with changing the station or playing the correct frequency, you may need to replace the tuner dial. Replacing the tuner dial on your radio will ensure that the alarm clock/radio can switch through different radio frequencies. Follow this guide for step-by-step instructions on replacing the tuner dial of your device.
你所需要的
Using the Phillips #00 screwdriver, remove four 14mm screws from the underside of the device.
