跳转到主内容
加入维修社区 - 创建账户
Sony FDL-220R Watchman Button Replacement
你所需要的
    1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: 步骤 1 中的图像 1,2 Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: 步骤 1 中的图像 2,2
      • Press down on the textured area and push towards the bottom of the device.
      • Gently remove the battery cover.
      • Remove the three AA batteries.
      询问修复机器人
      添加评论
    2. Sony FDL-220R Watchman Button Replacement, Remove screws: 步骤 2 中的图像 1,2 Sony FDL-220R Watchman Button Replacement, Remove screws: 步骤 2 中的图像 2,2
      • Locate the five 5x11mm screws surrounding the battery compartment.
      • Remove screws with a Philips #00 screwdriver.
      询问修复机器人
      添加评论
    3. Sony FDL-220R Watchman Button Replacement, Remove back casing: 步骤 3 中的图像 1,2 Sony FDL-220R Watchman Button Replacement, Remove back casing: 步骤 3 中的图像 2,2
      • Grasp the entire back half of the Watchman's casing.
      • Snap off the casing from the bottom of the device.
      • Gently pull off entire back casing.
      询问修复机器人
      添加评论
    4. Sony FDL-220R Watchman Button Replacement, Remove circuit board: 步骤 4 中的图像 1,3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: 步骤 4 中的图像 2,3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: 步骤 4 中的图像 3,3
      • Carefully grasp the entire circuit board.
      • Pull the circuit board off of the device's plastic casing.
      询问修复机器人
      添加评论
    5. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: 步骤 5 中的图像 1,2 Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: 步骤 5 中的图像 2,2
      • Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
      • Buttons/switches should be simply resting in their slots on the device.
      • Remove all three buttons/switches.
      • If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
      • If one of the buttons/switches is broken, simply replace it with a new one.
      • When replacing, make sure that the slot on the switches faces up.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Sam Putnam
于10/22/14注册
484 声望
创作了4篇指南
团队
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014 的会员
BU-WILLIAMS-F14S4G5
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 572
