跳转到主内容
加入维修社区 - 创建账户
Sony Ericsson Z500a Camera Replacement
你所需要的
  1. Sony Ericsson Z500a Camera Replacement, Keypad: 步骤 1 中的图像 1,3 Sony Ericsson Z500a Camera Replacement, Keypad: 步骤 1 中的图像 2,3 Sony Ericsson Z500a Camera Replacement, Keypad: 步骤 1 中的图像 3,3
    • Remove the back cover by pulling it down, and then take out the battery.
    • Using a T6 Torx screwdriver, remove the 4 screws.
    • Keep the phone open with the back cover facing you.
    询问修复机器人
    添加评论
  2. Sony Ericsson Z500a Camera Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
    • There are 2 clamps that lock the keyboard to the case (1 on each side)
    询问修复机器人
    添加评论
  3. Sony Ericsson Z500a Camera Replacement: 步骤 3 中的图像 1,1
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table) so that no loose parts fall out.
    询问修复机器人
    添加评论
  4. Sony Ericsson Z500a Camera Replacement, Logic Board: 步骤 4 中的图像 1,2 Sony Ericsson Z500a Camera Replacement, Logic Board: 步骤 4 中的图像 2,2
    • Use the opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
    • Gently lift the back of the logic board and then pull outwards. Be careful not to rip the ribbon wire.
    询问修复机器人
    添加评论
  5. Sony Ericsson Z500a Camera Replacement: 步骤 5 中的图像 1,2 Sony Ericsson Z500a Camera Replacement: 步骤 5 中的图像 2,2
    • Remove the black sim card reader and green vibrator before continuing to ensure they do not fall out.
    询问修复机器人
    添加评论
  6. Sony Ericsson Z500a Camera Replacement, Screen: 步骤 6 中的图像 1,2 Sony Ericsson Z500a Camera Replacement, Screen: 步骤 6 中的图像 2,2
    • Close the phone, flip it over, grab the remaining gray covering of the phone and pull it straight up to remove it.
    • Be careful when pulling upward to ensure that you do not break the piece below it.
    • Once the cover is removed, remove the black piece underneath.
    询问修复机器人
    添加评论
  7. Sony Ericsson Z500a Camera Replacement: 步骤 7 中的图像 1,2 Sony Ericsson Z500a Camera Replacement: 步骤 7 中的图像 2,2
    • Remove the face of the phone by sliding it down.
    • Unscrew the 4 screws connecting the screen to the base using a T6 Torx Screwdriver.
    询问修复机器人
    添加评论
  8. Sony Ericsson Z500a Camera Replacement: 步骤 8 中的图像 1,2 Sony Ericsson Z500a Camera Replacement: 步骤 8 中的图像 2,2
    • Use the opening tool to pry up the edge of the remaining silver hinge cover. Once it is loose, pull it off the rest of the way
    询问修复机器人
    添加评论
  9. Sony Ericsson Z500a Camera Replacement: 步骤 9 中的图像 1,2 Sony Ericsson Z500a Camera Replacement: 步骤 9 中的图像 2,2
    • To remove the plastic cover on the screen, run the opening tool along the sides between the cover and the body of the phone (like you did for the keyboard) and gently pry upward until it is loose.
    • Like the keyboard there is one clamp on each side.
    • Grab the cover at the bottom of the screen (near the hinge) and pull outward while leaving the top (near the speaker) connected.
    询问修复机器人
    添加评论
  10. Sony Ericsson Z500a Camera Replacement: 步骤 10 中的图像 1,1
    • Remove the tape on the bottom of the screen so that the screen will be able to come out.
    • There is a finger notch on the top of the screen, gently pull out halfway.
    • Caution: the back of the screen is connected to the base of the phone. So do not pull out or the connection will be broken.
    询问修复机器人
    添加评论
  11. Sony Ericsson Z500a Camera Replacement: 步骤 11 中的图像 1,1
    • Use the opening device to remove the ribbon wire where it connects to the screen.
    询问修复机器人
    添加评论
  12. Sony Ericsson Z500a Camera Replacement, Camera: 步骤 12 中的图像 1,1
    • Use iPod opening device to remove the metal cover.
    询问修复机器人
    添加评论
  13. Sony Ericsson Z500a Camera Replacement: 步骤 13 中的图像 1,1
    • Gently pop off the ribbon wire with the plastic opening tool.
    询问修复机器人
    添加评论
  14. Sony Ericsson Z500a Camera Replacement: 步骤 14 中的图像 1,1
    • Flip the phone over and gently use iPod opening device to remove the right half of the black tape.
    • Be careful because the tape is holding a ribbon wire.
    询问修复机器人
    添加评论
  15. Sony Ericsson Z500a Camera Replacement: 步骤 15 中的图像 1,2 Sony Ericsson Z500a Camera Replacement: 步骤 15 中的图像 2,2
    • Push metal camera cover through the hole to remove camera.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Richard
于04/16/10注册
3 声望
撰写一个指南
团队
Cal Poly, Team 7-12, Maness Spring 2010 Cal Poly, Team 7-12, Maness Spring 2010 的会员
CPSU-MANESS-S10S7G12
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 25
总计 2,059
