跳转到主内容
加入维修社区 - 创建账户
Sony Ericsson W350a Screen Replacement
你所需要的
  1. Sony Ericsson W350a Screen Replacement, Flip Cover: 步骤 1 中的图像 1,1
    • Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove the cover.
    询问修复机器人
    添加评论
  2. Sony Ericsson W350a Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the cover with a slight twisting motion.
    询问修复机器人
    添加评论
  3. Sony Ericsson W350a Screen Replacement, Battery: 步骤 3 中的图像 1,2 Sony Ericsson W350a Screen Replacement, Battery: 步骤 3 中的图像 2,2
    • Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
    询问修复机器人
    添加评论
  4. Sony Ericsson W350a Screen Replacement: 步骤 4 中的图像 1,3 Sony Ericsson W350a Screen Replacement: 步骤 4 中的图像 2,3 Sony Ericsson W350a Screen Replacement: 步骤 4 中的图像 3,3
    • Set the cover to the side upon removal.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately.
    询问修复机器人
    添加评论
  5. Sony Ericsson W350a Screen Replacement, Speaker: 步骤 5 中的图像 1,2 Sony Ericsson W350a Screen Replacement, Speaker: 步骤 5 中的图像 2,2
    • Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker.
    • Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
    询问修复机器人
    添加评论
  6. Sony Ericsson W350a Screen Replacement: 步骤 6 中的图像 1,1
    • Using a mini Phillips screwdriver, remove two screws by turning them counterclockwise.
    询问修复机器人
    添加评论
  7. Sony Ericsson W350a Screen Replacement: 步骤 7 中的图像 1,1
    • Insert an opening tool in the bottom crack between the front and back plates and use a gentle upward pull to separate the back case from the front case.
    • Side buttons/controls may fall from their place in between the back and front casings.
    询问修复机器人
    添加评论
  8. Sony Ericsson W350a Screen Replacement: 步骤 8 中的图像 1,1
    • Using a T5 screwdriver, remove the two screws by turning them counterclockwise.
    询问修复机器人
    添加评论
  9. Sony Ericsson W350a Screen Replacement: 步骤 9 中的图像 1,2 Sony Ericsson W350a Screen Replacement: 步骤 9 中的图像 2,2
    • Using an opening tool and a gentle outward motion, separate the front plate from the inner phone workings.
    询问修复机器人
    添加评论
  10. Sony Ericsson W350a Screen Replacement: 步骤 10 中的图像 1,2 Sony Ericsson W350a Screen Replacement: 步骤 10 中的图像 2,2
    • Using a Phillips head screwdriver, remove the screw from the front number pad by turning it counterclockwise.
    • Remove the speaker from the phone.
    询问修复机器人
    添加评论
  11. Sony Ericsson W350a Screen Replacement, Keypad: 步骤 11 中的图像 1,3 Sony Ericsson W350a Screen Replacement, Keypad: 步骤 11 中的图像 2,3 Sony Ericsson W350a Screen Replacement, Keypad: 步骤 11 中的图像 3,3
    • Disconnect the ribbon cable from its connection until the keypad "pops" off.
    • Remove the keypad from the phone.
    询问修复机器人
    添加评论
  12. Sony Ericsson W350a Screen Replacement, Screen: 步骤 12 中的图像 1,3 Sony Ericsson W350a Screen Replacement, Screen: 步骤 12 中的图像 2,3 Sony Ericsson W350a Screen Replacement, Screen: 步骤 12 中的图像 3,3
    • After removing the keypad, gently pry apart the screen from the frame of the phone using your fingers and thumbs on opposite sides as shown.
    • Even though the screen is detached from the frame, it will still be electronically connected in a similar fashion as the keypad. This connection is shown in the second picture. To sever this connection, gently pull the wire tape until the male member pops out of its counterpart of the phone.
    • Once the screen and keypad are removed, the assembly of the phone should be as shown in the third picture.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Ldellos
于03/12/12注册
112 声望
创作了3篇指南
团队
Clemson, Team 1-4, Benson Spring 2012 Clemson, Team 1-4, Benson Spring 2012 的会员
CLEM-BENSON-S12S1G4
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 46
总计 2,075
