跳转到主内容
加入维修社区 - 创建账户
Sony CPF-IP001 Subwoofer Replacement
你所需要的
    1. Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: 步骤 1 中的图像 1,2 Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: 步骤 1 中的图像 2,2
      • Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
      • Once all of the screws are removed, the cover can be taken off using a metal spudger.
      询问修复机器人
      添加评论
    2. Sony CPF-IP001 Subwoofer Replacement: 步骤 2 中的图像 1,2 Sony CPF-IP001 Subwoofer Replacement: 步骤 2 中的图像 2,2
      • Remove eight 14 mm Phillips #2 screws holding the circuit board in place.
      • Using the plastic opening tool, carefully remove the circuit board.
      • There will be 3 wires connected to the opposite side of the circuit board. Be careful not to pull the board out of the device too far and damage these wires.
      询问修复机器人
      添加评论
    3. Sony CPF-IP001 Subwoofer Replacement: 步骤 3 中的图像 1,2 Sony CPF-IP001 Subwoofer Replacement: 步骤 3 中的图像 2,2
      • Remove the first of the three wires by squeezing the clip and pulling it out.
      • After disconnecting the first wire, the two attached wires can be more easily accessed.
      询问修复机器人
      添加评论
    4. Sony CPF-IP001 Subwoofer Replacement: 步骤 4 中的图像 1,3 Sony CPF-IP001 Subwoofer Replacement: 步骤 4 中的图像 2,3 Sony CPF-IP001 Subwoofer Replacement: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      • Remove the wire furthest to the left by squeezing the clip and pulling it out.
      • Detach the third wire by carefully using the tweezers.
      • The circuit board is now completely detached and can be set aside.
      询问修复机器人
      添加评论
    5. Sony CPF-IP001 Subwoofer Replacement: 步骤 5 中的图像 1,2 Sony CPF-IP001 Subwoofer Replacement: 步骤 5 中的图像 2,2
      • Remove six 8 mm Phillips #2 screws.
      • Slide the side panel with the power cord out from the housing.
      • The side panel with the power cord will come out as a whole unit with the subwoofer air tunnel.
      询问修复机器人
      添加评论
    1. Sony CPF-IP001 Subwoofer Replacement, Subwoofer: 步骤 6 中的图像 1,1
      • Remove two 8 mm Phillips #2 screws holding the side panel in place.
      询问修复机器人
      添加评论
    2. Sony CPF-IP001 Subwoofer Replacement: 步骤 7 中的图像 1,1
      • Remove eight 8 mm Phillips #2 screws holding the subwoofer tray to the housing.
      询问修复机器人
      添加评论
    3. Sony CPF-IP001 Subwoofer Replacement: 步骤 8 中的图像 1,2 Sony CPF-IP001 Subwoofer Replacement: 步骤 8 中的图像 2,2
      • Using a metal spudger, slightly peel back the plastic the has been glued to the tray and the housing.
      • Slide the tray containing the subwoofer out of the housing.
      询问修复机器人
      添加评论
    4. Sony CPF-IP001 Subwoofer Replacement: 步骤 9 中的图像 1,2 Sony CPF-IP001 Subwoofer Replacement: 步骤 9 中的图像 2,2
      • After removing the tray, flip it over and you will find four screws connecting the subwoofer.
      • Remove four 7.5 mm Phillips #2 screws.
      询问修复机器人
      添加评论
    5. Sony CPF-IP001 Subwoofer Replacement: 步骤 10 中的图像 1,2 Sony CPF-IP001 Subwoofer Replacement: 步骤 10 中的图像 2,2
      • The subwoofer has now been removed from the device and can be replaced.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Mike Bolton
于04/14/15注册
473 声望
创作了4篇指南
团队
Cal Poly, Team 6-14, Maness Spring 2015 Cal Poly, Team 6-14, Maness Spring 2015 的会员
CPSU-MANESS-S15S6G14
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 38
总计 1,161
