跳转到主内容
加入维修社区 - 创建账户
Sony CPF-IP001 Power Cord Replacement
你所需要的
    1. Sony CPF-IP001 Power Cord Replacement, Subwoofer Housing Disassembly: 步骤 1 中的图像 1,2 Sony CPF-IP001 Power Cord Replacement, Subwoofer Housing Disassembly: 步骤 1 中的图像 2,2
      • Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
      • Once all of the screws are removed, the cover can be taken off using a metal spudger.
      询问修复机器人
      添加评论
    2. Sony CPF-IP001 Power Cord Replacement: 步骤 2 中的图像 1,2 Sony CPF-IP001 Power Cord Replacement: 步骤 2 中的图像 2,2
      • Remove eight 14 mm Phillips #2 screws holding the circuit board in place.
      • Using the plastic opening tool, carefully remove the circuit board.
      • There will be 3 wires connected to the opposite side of the circuit board. Be careful not to pull the board out of the device too far and damage these wires.
      询问修复机器人
      添加评论
    3. Sony CPF-IP001 Power Cord Replacement: 步骤 3 中的图像 1,2 Sony CPF-IP001 Power Cord Replacement: 步骤 3 中的图像 2,2
      • Remove the first of the three wires by squeezing the clip and pulling it out.
      • After disconnecting the first wire, the two attached wires can be more easily accessed.
      询问修复机器人
      添加评论
    4. Sony CPF-IP001 Power Cord Replacement: 步骤 4 中的图像 1,3 Sony CPF-IP001 Power Cord Replacement: 步骤 4 中的图像 2,3 Sony CPF-IP001 Power Cord Replacement: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      • Remove the wire furthest to the left by squeezing the clip and pulling it out.
      • Detach the third wire by carefully using the tweezers.
      • The circuit board is now completely detached and can be set aside.
      询问修复机器人
      添加评论
    5. Sony CPF-IP001 Power Cord Replacement: 步骤 5 中的图像 1,2 Sony CPF-IP001 Power Cord Replacement: 步骤 5 中的图像 2,2
      • Remove six 8 mm Phillips #2 screws.
      • Slide the side panel with the power cord out from the housing.
      • The side panel with the power cord will come out as a whole unit with the subwoofer air tunnel.
      询问修复机器人
      添加评论
    1. Sony CPF-IP001 Power Cord Replacement, Power Cord: 步骤 6 中的图像 1,2 Sony CPF-IP001 Power Cord Replacement, Power Cord: 步骤 6 中的图像 2,2
      • Remove four 8 mm Phillips #2 screws.
      • Detach the air tube from the side panel.
      询问修复机器人
      添加评论
    2. Sony CPF-IP001 Power Cord Replacement: 步骤 7 中的图像 1,2 Sony CPF-IP001 Power Cord Replacement: 步骤 7 中的图像 2,2
      • Begin to pry the power cord cover unit from the side panel using a metal spudger.
      • Feed the wires that come out of the side panel through the glue and into the power cord cover unit to get the cover farther away from the side panel.
      询问修复机器人
      添加评论
    3. Sony CPF-IP001 Power Cord Replacement: 步骤 8 中的图像 1,2 Sony CPF-IP001 Power Cord Replacement: 步骤 8 中的图像 2,2
      • Using a metal spudger, disconnect the four spade connectors that are connected to the power button and the power cord.
      询问修复机器人
      添加评论
    4. Sony CPF-IP001 Power Cord Replacement: 步骤 9 中的图像 1,2 Sony CPF-IP001 Power Cord Replacement: 步骤 9 中的图像 2,2
      • Using a metal spudger, press the tab on top of the power cord and push the power cord through the side panel.
      • Once through, the clip connected to the power cord will open up and a new power cord can be put in place.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Mike Bolton
于04/14/15注册
473 声望
创作了4篇指南
团队
Cal Poly, Team 6-14, Maness Spring 2015 Cal Poly, Team 6-14, Maness Spring 2015 的会员
CPSU-MANESS-S15S6G14
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 38
总计 700
