跳转到主内容
加入维修社区 - 创建账户
Sony CFD-8 Front Panel Replacement
你所需要的
  1. Sony CFD-8 Front Panel Replacement, Battery: 步骤 1 中的图像 1,3 Sony CFD-8 Front Panel Replacement, Battery: 步骤 1 中的图像 2,3 Sony CFD-8 Front Panel Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
    • Be sure to unplug the boombox from the wall before attempting to open it for repair.
    询问修复机器人
    添加评论
  2. Sony CFD-8 Front Panel Replacement: 步骤 2 中的图像 1,2 Sony CFD-8 Front Panel Replacement: 步骤 2 中的图像 2,2
    • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
    • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
    询问修复机器人
    添加评论
  3. Sony CFD-8 Front Panel Replacement, Front Panel: 步骤 3 中的图像 1,3 Sony CFD-8 Front Panel Replacement, Front Panel: 步骤 3 中的图像 2,3 Sony CFD-8 Front Panel Replacement, Front Panel: 步骤 3 中的图像 3,3
    • Hold the boombox handle at an angle to access the screws behind the CD player.
    • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
    询问修复机器人
    添加评论
  4. Sony CFD-8 Front Panel Replacement: 步骤 4 中的图像 1,2 Sony CFD-8 Front Panel Replacement: 步骤 4 中的图像 2,2
    • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
    • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
    询问修复机器人
    添加评论
  5. Sony CFD-8 Front Panel Replacement: 步骤 5 中的图像 1,3 Sony CFD-8 Front Panel Replacement: 步骤 5 中的图像 2,3 Sony CFD-8 Front Panel Replacement: 步骤 5 中的图像 3,3
    • Gently separate the front panel from the back panel.
    • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
    • Remove the front panel.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Andrew Kleve
于10/12/14注册
271 声望
创作了2篇指南
团队
Cal Poly, Team 10-38, Amido Fall 2014 Cal Poly, Team 10-38, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G38
5 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 46
总计 4,183
