跳转到主内容
加入维修社区 - 创建账户
Sony BDP-S1 Optical Drive Replacement
你所需要的
  1. Sony BDP-S1 Optical Drive Replacement, Sony BDP-S1: Getting inside the device: 步骤 1 中的图像 1,2 Sony BDP-S1 Optical Drive Replacement, Sony BDP-S1: Getting inside the device: 步骤 1 中的图像 2,2
    • Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
    • Don't forget, there are two more 12mm screws on the other side as well.
    询问修复机器人
    添加评论
  2. Sony BDP-S1 Optical Drive Replacement: 步骤 2 中的图像 1,3 Sony BDP-S1 Optical Drive Replacement: 步骤 2 中的图像 2,3 Sony BDP-S1 Optical Drive Replacement: 步骤 2 中的图像 3,3
    • First, remove the three 12mm black screws holding the top panel on (Phillips #2).
    • Then, remove the two 12mm black screws - one on each side of the back of the device - holding the top panel on.
    • Lastly, remove the three 12mm black screws on each side of device.
    询问修复机器人
    添加评论
  3. Sony BDP-S1 Optical Drive Replacement: 步骤 3 中的图像 1,3 Sony BDP-S1 Optical Drive Replacement: 步骤 3 中的图像 2,3 Sony BDP-S1 Optical Drive Replacement: 步骤 3 中的图像 3,3
    • Potential for device damage: Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
    • After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
    询问修复机器人
    添加评论
  4. Sony BDP-S1 Optical Drive Replacement: 步骤 4 中的图像 1,3 Sony BDP-S1 Optical Drive Replacement: 步骤 4 中的图像 2,3 Sony BDP-S1 Optical Drive Replacement: 步骤 4 中的图像 3,3
    • After the top is off, you'll see that there are two metal bars that go across the top of the device.
    • Remove each bar by unscrewing the two 10mm silver screws on each end.
    询问修复机器人
    添加评论
  5. Sony BDP-S1 Optical Drive Replacement, Optical Drive: 步骤 5 中的图像 1,3 Sony BDP-S1 Optical Drive Replacement, Optical Drive: 步骤 5 中的图像 2,3 Sony BDP-S1 Optical Drive Replacement, Optical Drive: 步骤 5 中的图像 3,3
    • Remove the two 10mm silver screws holding the front panel on with the Phillips #2 screwdriver, located on the top side of the front panel.
    • Take off the front panel by depressing the clips (either with your fingers, screwdriver, or other small object) and pulling it off.
    • There are two clips on the top, one on each side, and three on the bottom.
    询问修复机器人
    添加评论
  6. Sony BDP-S1 Optical Drive Replacement: 步骤 6 中的图像 1,2 Sony BDP-S1 Optical Drive Replacement: 步骤 6 中的图像 2,2
    • Before unscrewing the optical drive enclosure, the small cable on the left of the drive (when looking at the device from the back) needs to be disconnected from the circuit board (the orange one).
    • Also, take the cables out of the white clip that is on the side of the optical drive.
    询问修复机器人
    添加评论
  7. Sony BDP-S1 Optical Drive Replacement: 步骤 7 中的图像 1,3 Sony BDP-S1 Optical Drive Replacement: 步骤 7 中的图像 2,3 Sony BDP-S1 Optical Drive Replacement: 步骤 7 中的图像 3,3
    • Unscrew the two metal clamps on both sides of the optical drive by removing three sets of screws:
    • The two 10mm silver screws on the bottom of the each clamp.
    • The 10mm silver screw holding each clamp from the front.
    • The two 5mm black screws on the sides.
    • Remove the two clamps. They can be removed by hand.
    询问修复机器人
    添加评论
  8. Sony BDP-S1 Optical Drive Replacement: 步骤 8 中的图像 1,3 Sony BDP-S1 Optical Drive Replacement: 步骤 8 中的图像 2,3 Sony BDP-S1 Optical Drive Replacement: 步骤 8 中的图像 3,3
    • Gently pull the optical drive back to dislodge it from the front of the device and then lift it up.
    • Remove the wide ribbon cable from the back of the optical drive.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Sam
于01/26/14注册
376 声望
创作了3篇指南
团队
Cal Poly, Team 9-30, Maness Winter 2014 Cal Poly, Team 9-30, Maness Winter 2014 的会员
CPSU-MANESS-W14S9G30
3 名成员
创作了10篇指南
1指南评论
Hi Sam, thanks for your guide!
How can I find a new drive for my BDP-S1E?
I've asked to local Sony but seems not more available..
Thank You so much
Romano
romanojeran - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 36
总计 2,363
