跳转到主内容
加入维修社区 - 创建账户
Sony BDP-BX520 Disc Reader Replacement
你所需要的
  1. Sony BDP-BX520 Disc Reader Replacement, Disc Tray Cover: 步骤 1 中的图像 1,1
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
    添加评论
  2. Sony BDP-BX520 Disc Reader Replacement: 步骤 2 中的图像 1,1
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
    询问修复机器人
    添加评论
  3. Sony BDP-BX520 Disc Reader Replacement: 步骤 3 中的图像 1,1
    • Close the disc tray, then power off and unplug the Blu-Ray player.
    询问修复机器人
    添加评论
  4. Sony BDP-BX520 Disc Reader Replacement, Top Case: 步骤 4 中的图像 1,1
    • Locate the three 8 mm screws on the back of the Blu-Ray player.
    • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
    询问修复机器人
    添加评论
  5. Sony BDP-BX520 Disc Reader Replacement: 步骤 5 中的图像 1,2 Sony BDP-BX520 Disc Reader Replacement: 步骤 5 中的图像 2,2
    • Gently pull the top case back to remove it from the Blu-Ray player.
    询问修复机器人
    添加评论
  6. Sony BDP-BX520 Disc Reader Replacement, Front Panel: 步骤 6 中的图像 1,1
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
    询问修复机器人
    添加评论
  7. Sony BDP-BX520 Disc Reader Replacement: 步骤 7 中的图像 1,1
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
    询问修复机器人
    添加评论
  8. Sony BDP-BX520 Disc Reader Replacement: 步骤 8 中的图像 1,1
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
    询问修复机器人
    添加评论
  9. Sony BDP-BX520 Disc Reader Replacement: 步骤 9 中的图像 1,2 Sony BDP-BX520 Disc Reader Replacement: 步骤 9 中的图像 2,2
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
    询问修复机器人
    添加评论
  10. Sony BDP-BX520 Disc Reader Replacement, Disc Reader: 步骤 10 中的图像 1,1
    • Do not touch the circuit boards or the internal parts of the device while it is powered on. This could short out the circuits and possibly cause you harm.
    • Plug in the device and power it on by pushing the right button on the front of the device. The light should turn on.
    询问修复机器人
    添加评论
  11. Sony BDP-BX520 Disc Reader Replacement: 步骤 11 中的图像 1,1
    • Eject the disc tray by pushing the left button on the front of the device.
    • Unplug the device once the disc tray is open.
    询问修复机器人
    添加评论
  12. Sony BDP-BX520 Disc Reader Replacement: 步骤 12 中的图像 1,1
    • Insert the nylon or metal spudger under the clip and lift it up. There are 4 clips that need to be lifted, two on each side
    询问修复机器人
    添加评论
  13. Sony BDP-BX520 Disc Reader Replacement: 步骤 13 中的图像 1,2 Sony BDP-BX520 Disc Reader Replacement: 步骤 13 中的图像 2,2
    • Once the clips are free, lift the top cover of the disc tray up.
    • This should take minimal force.
    询问修复机器人
    添加评论
  14. Sony BDP-BX520 Disc Reader Replacement: 步骤 14 中的图像 1,1
    • Unscrew the two silver 8mm Phillips 1 screws from the disc reader.
    询问修复机器人
    添加评论
  15. Sony BDP-BX520 Disc Reader Replacement: 步骤 15 中的图像 1,3 Sony BDP-BX520 Disc Reader Replacement: 步骤 15 中的图像 2,3 Sony BDP-BX520 Disc Reader Replacement: 步骤 15 中的图像 3,3
    在这个步骤中使用的工具:
    • Use the tweezers to lift both sides of the black clip holding the white 14 pin ribbon in place.
    • Once free the white 24 pin ribbon should slip right out.
    询问修复机器人
    添加评论
  16. Sony BDP-BX520 Disc Reader Replacement: 步骤 16 中的图像 1,2 Sony BDP-BX520 Disc Reader Replacement: 步骤 16 中的图像 2,2
    • Carefully lift up the disc reader. It is still attached by a cable underneath!
    询问修复机器人
    添加评论
  17. Sony BDP-BX520 Disc Reader Replacement: 步骤 17 中的图像 1,2 Sony BDP-BX520 Disc Reader Replacement: 步骤 17 中的图像 2,2
    • Gently pull out the white 13 pin cable from the disc reader.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Kyle Smit
于01/31/15注册
243 声望
创作了2篇指南
团队
Cal Poly, Team 8-41, Amido Winter 2015 Cal Poly, Team 8-41, Amido Winter 2015 的会员
CPSU-AMIDO-W15S8G41
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 32
总计 1,641
