跳转到主内容
加入维修社区 - 创建账户
Sony Alpha NEX-6 Lens Mount Replacement
你所需要的
    1. Sony Alpha NEX-6 Lens Mount Replacement, Finding the Release Button: 步骤 1 中的图像 1,1
      • Turn the camera with the lens facing up.
      • Find the lens release button - located along the side of the silver lens mount.
      添加评论
    2. Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: 步骤 2 中的图像 1,2 Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: 步骤 2 中的图像 2,2
      • Press and hold the lens release button while rotating the lens counterclockwise.
      • Lift the lens when it is no longer attached to the camera.
      • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
      • Insert the lens and rotate it clockwise until it is locked in place.
      询问修复机器人
      添加评论
    1. Sony Alpha NEX-6 Lens Mount Replacement, Lens Mount: 步骤 3 中的图像 1,1
      • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
      • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
      • The outer lens mount ring can now be removed.
      询问修复机器人
      添加评论
    2. Sony Alpha NEX-6 Lens Mount Replacement: 步骤 4 中的图像 1,3 Sony Alpha NEX-6 Lens Mount Replacement: 步骤 4 中的图像 2,3 Sony Alpha NEX-6 Lens Mount Replacement: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      • Pay attention to the positioning of the spacer rings for reassembly.
      • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
      • Repeat this step for the second (silver) spacer ring.
      • The third image is what the camera should look like after all spacer rings are removed.
      询问修复机器人
      添加评论
    3. Sony Alpha NEX-6 Lens Mount Replacement: 步骤 5 中的图像 1,2 Sony Alpha NEX-6 Lens Mount Replacement: 步骤 5 中的图像 2,2
      • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Clayton Dale
于01/20/15注册
1,067 声望
创作了7篇指南
团队
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S11G2
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 41
总计 2,227
