跳转到主内容
加入维修社区 - 创建账户
Sony Alpha NEX-6 LCD Screen Replacement
你所需要的
    1. Sony Alpha NEX-6 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
      • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
      • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
      询问修复机器人
      添加评论
    2. Sony Alpha NEX-6 LCD Screen Replacement: 步骤 2 中的图像 1,1
      • Flip the camera upside-down and carefully place it on a flat surface.
      • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
      • Push the latch to the right to unlock the battery compartment. The door should flip upward.
      询问修复机器人
      添加评论
    3. Sony Alpha NEX-6 LCD Screen Replacement: 步骤 3 中的图像 1,1
      • With the compartment open, locate a blue tab shown with spudger
      • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
      询问修复机器人
      添加评论
    1. Sony Alpha NEX-6 LCD Screen Replacement, Removing back screws: 步骤 4 中的图像 1,1
      • Remove the two 1.0 mm Phillips #00 screws from back of the LCD screen.
      询问修复机器人
      添加评论
    2. Sony Alpha NEX-6 LCD Screen Replacement, Removing bottom screws: 步骤 5 中的图像 1,1
      • Remove the two 1.5 mm Phillips #00 screws from the bottom of the screen mount assembly.
      询问修复机器人
      添加评论
    3. Sony Alpha NEX-6 LCD Screen Replacement, Back cover: 步骤 6 中的图像 1,2 Sony Alpha NEX-6 LCD Screen Replacement, Back cover: 步骤 6 中的图像 2,2
      在这个步骤中使用的工具:
      • Using a plastic opening tool pry off the back cover from the screen assembly.
      • Remove back cover by lifting it away from the screen using tweezers.
      询问修复机器人
      添加评论
    4. Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: 步骤 7 中的图像 1,3 Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: 步骤 7 中的图像 2,3 Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: 步骤 7 中的图像 3,3
      • Release the ribbon cable by lifting the black locking latch with the plastic opening tool.
      • Pry out the ribbon cable by carefully sliding it out of the connection slot using a spudger.
      询问修复机器人
      添加评论
    5. Sony Alpha NEX-6 LCD Screen Replacement, Upper plastic separator: 步骤 8 中的图像 1,1
      • Lift and slide out the upper black plastic separator using tweezers.
      询问修复机器人
      添加评论
    6. Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: 步骤 9 中的图像 1,3 Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: 步骤 9 中的图像 2,3 Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: 步骤 9 中的图像 3,3
      • Lift and remove the lower black plastic separator using tweezers.
      • Using the pointy side of a spudger push in the screen lock button release it.
      • The screen lock button can now be removed.
      询问修复机器人
      添加评论
    7. Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: 步骤 10 中的图像 1,3 Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: 步骤 10 中的图像 2,3 Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: 步骤 10 中的图像 3,3
      • Using the flat end of the spudger, push on the black nylon sheet glued to the metallic frame to peel it of.
      • Apply force from different spots to avoid tearing the sheet.
      • Remove the black nylon sheet using tweezers.
      询问修复机器人
      添加评论
    8. Sony Alpha NEX-6 LCD Screen Replacement, Screen Removal: 步骤 11 中的图像 1,1
      • Gently wiggle the screen loose and remove it from the mount.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
Clayton Dale
于01/20/15注册
1,067 声望
创作了7篇指南
团队
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S11G2
4 名成员
创作了14篇指南
2指南评论
Thanks a million! Great guide and saved me $250 sending it back in.
Al Weiner - 回复 分享
Hi - I am trying to fix one of these -- and the guy I bought it from pulled off and lost the black locking latch from the ribbon cable rather than just lifting it -- I can get the LCD screen to light but can't keep it on very long -- I bought another one of these internal cables with the black locking latch. Do you think I can pop that one off and move it to this one? Or do you have any source of instructions how to replace that cable?
Cheers and thanks for this!
PS -- If anyone is just trying to get rid of the dreaded bubbles in the screen saver that plagues these NEX cameras -- it does just peal off -- see youtubes,,,
Harvey Cat - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 51
总计 8,218
