跳转到主内容
加入维修社区 - 创建账户
Sony Alpha NEX-6 Control Wheel Replacement
你所需要的
    1. Sony Alpha NEX-6 Control Wheel Replacement, Battery: 步骤 1 中的图像 1,1
      • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
      • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
      询问修复机器人
      添加评论
    2. Sony Alpha NEX-6 Control Wheel Replacement: 步骤 2 中的图像 1,1
      • Flip the camera upside-down and carefully place it on a flat surface.
      • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
      • Push the latch to the right to unlock the battery compartment. The door should flip upward.
      询问修复机器人
      添加评论
    3. Sony Alpha NEX-6 Control Wheel Replacement: 步骤 3 中的图像 1,1
      • With the compartment open, locate a blue tab shown with spudger
      • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
      询问修复机器人
      添加评论
    1. Sony Alpha NEX-6 Control Wheel Replacement, Battery compartment screws: 步骤 4 中的图像 1,1
      • Remove the two 3.5mm Phillips #00 screws that hold the back case - located inside the battery compartment.
      询问修复机器人
      添加评论
    2. Sony Alpha NEX-6 Control Wheel Replacement, Bottom screws: 步骤 5 中的图像 1,1
      • Remove the two 3.5mm Phillips #00 screws that hold the back case - located on the bottom of the camera.
      询问修复机器人
      添加评论
    3. Sony Alpha NEX-6 Control Wheel Replacement, Side screws: 步骤 6 中的图像 1,1
      • Remove the 3.5 mm Phillips #00 screw on the side of camera - located between the charging and HDMI ports.
      • Remove the 4.0 mm Phillips #00 screw on the side of the camera - located next to the WiFi sign.
      询问修复机器人
      添加评论
    4. Sony Alpha NEX-6 Control Wheel Replacement, Dis-attaching procedure: 步骤 7 中的图像 1,2 Sony Alpha NEX-6 Control Wheel Replacement, Dis-attaching procedure: 步骤 7 中的图像 2,2
      • Starting with the battery compartment gently begin to separate the back case front the camera.
      • Using a plastic opening tool, separate the bottom of the back case from the camera. Then proceed by separating the sides.
      • Gently lift the back case away from the camera an slide it down to completely remove the back case.
      询问修复机器人
      添加评论
    1. Sony Alpha NEX-6 Control Wheel Replacement, Control Wheel: 步骤 8 中的图像 1,2 Sony Alpha NEX-6 Control Wheel Replacement, Control Wheel: 步骤 8 中的图像 2,2
      • Pry out the ribbon cable by carefully pushing on its side tabs with a spudger.
      询问修复机器人
      添加评论
    2. Sony Alpha NEX-6 Control Wheel Replacement, Control wheel romoval: 步骤 9 中的图像 1,2 Sony Alpha NEX-6 Control Wheel Replacement, Control wheel romoval: 步骤 9 中的图像 2,2
      在这个步骤中使用的工具:
      • Using a spudger, lift the metal locking tab located at the top right corner of control wheel assembly.
      • Using tweezers, carefully slide the assembly up to release it.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Clayton Dale
于01/20/15注册
1,067 声望
创作了7篇指南
团队
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S11G2
4 名成员
创作了63篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 56
总计 6,056
