跳转到主内容
加入维修社区 - 创建账户
Sony Alpha NEX-6 Battery Replacement
你所需要的
    1. Sony Alpha NEX-6 Battery Replacement, Battery: 步骤 1 中的图像 1,1
      • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
      • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
      询问修复机器人
      添加评论
    2. Sony Alpha NEX-6 Battery Replacement: 步骤 2 中的图像 1,1
      • Flip the camera upside-down and carefully place it on a flat surface.
      • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
      • Push the latch to the right to unlock the battery compartment. The door should flip upward.
      询问修复机器人
      添加评论
    3. Sony Alpha NEX-6 Battery Replacement: 步骤 3 中的图像 1,1
      • With the compartment open, locate a blue tab shown with spudger
      • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Clayton Dale
于01/20/15注册
1,067 声望
创作了7篇指南
团队
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S11G2
4 名成员
创作了14篇指南
3指南评论
Battery Stuck
rustychinnis - 回复 分享
Will not spring out. Any ideas?
Got it, battery damaged. Tapped on edge to remove battery
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 32
总计 3,051
