跳转到主内容
加入维修社区 - 创建账户
Sony Alpha 6000 Shutter Button Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
    1. Sony Alpha 6000 Shutter Button Replacement, Battery: 步骤 1 中的图像 1,1
      • Make sure the camera is turned off by turning the switch to OFF.
      询问修复机器人
      添加评论
    2. Sony Alpha 6000 Shutter Button Replacement: 步骤 2 中的图像 1,1
      • Flip the camera around to access the battery compartment.
      • Slide the battery compartment lock to the left to unlock it.
      询问修复机器人
      添加评论
    3. Sony Alpha 6000 Shutter Button Replacement: 步骤 3 中的图像 1,1
      • Locate the blue latch that holds the battery in.
      询问修复机器人
      添加评论
    4. Sony Alpha 6000 Shutter Button Replacement: 步骤 4 中的图像 1,1
      • Push the latch back to release battery.
      询问修复机器人
      添加评论
    5. Sony Alpha 6000 Shutter Button Replacement: 步骤 5 中的图像 1,1
      • The battery can now be taken out of its compartment.
      询问修复机器人
      添加评论
    1. Sony Alpha 6000 Shutter Button Replacement, Back Cover: 步骤 6 中的图像 1,1
      • Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
      添加评论
    2. Sony Alpha 6000 Shutter Button Replacement: 步骤 7 中的图像 1,1
      • Turn the camera sideways.
      • Open the mini HDMI compartment and locate the two 6 mm screw underneath and another to the right of the compartment.
      • Unscrew using the J00 head screw.
      添加评论
    3. Sony Alpha 6000 Shutter Button Replacement: 步骤 8 中的图像 1,1
      • Locate the two 4 mm screws within the battery compartment and unscrew them using the J00 screw head.
      添加评论
    4. Sony Alpha 6000 Shutter Button Replacement: 步骤 9 中的图像 1,1
      • Bend the camera's screen forward to uncover two 3 mm screws below the eyepiece.
      • Locate them and unscrew them.
      添加评论
    5. Sony Alpha 6000 Shutter Button Replacement: 步骤 10 中的图像 1,2 Sony Alpha 6000 Shutter Button Replacement: 步骤 10 中的图像 2,2
      • Use a plastic opening tool around the body of the camera to wedge the back cover off. Start from the bottom next to the battery compartment.
      • If necessary, lightly use your hand to pull the the back cover down to completely remove it.
      添加评论
    1. Sony Alpha 6000 Shutter Button Replacement, Shutter Button: 步骤 11 中的图像 1,1
      • Once the back cover is off, locate the flash of the camera and push it forward to open it
      询问修复机器人
      添加评论
    2. Sony Alpha 6000 Shutter Button Replacement: 步骤 12 中的图像 1,1
      • Locate the two 3 mm screws within the flash and unscrew them
      询问修复机器人
      添加评论
    3. Sony Alpha 6000 Shutter Button Replacement: 步骤 13 中的图像 1,1
      • Hold the camera from the bottom and using a spudger, go around the top of the camera and separate the top plastic piece from the main body.
      询问修复机器人
      添加评论
    4. Sony Alpha 6000 Shutter Button Replacement: 步骤 14 中的图像 1,2 Sony Alpha 6000 Shutter Button Replacement: 步骤 14 中的图像 2,2
      • Hold the top of the camera away from the body.
      • Carefully turn it over to uncover the bottom of the shutter button.
      询问修复机器人
      添加评论
    5. Sony Alpha 6000 Shutter Button Replacement: 步骤 15 中的图像 1,1
      • Locate the two screws holding the shutter button and unscrew them.
      询问修复机器人
      添加评论
    6. Sony Alpha 6000 Shutter Button Replacement: 步骤 16 中的图像 1,1
      在这个步骤中使用的工具:
      • Once the screws are out, use a pair of tweezers to pull out the circular metal piece under the shutter button.
      询问修复机器人
      添加评论
    7. Sony Alpha 6000 Shutter Button Replacement: 步骤 17 中的图像 1,1
      • Turn the top plastic piece back over.
      • Now you will be able to completely remove the camera's shutter button.
      询问修复机器人
      添加评论
结论
Now that the shutter button is removed, you will be able to replace it with a new piece. To reassemble your device, follow these instructions in reverse order.
取消:我没有完成这个指南。
7等其他人完成本指南。
团队
USF Tampa, Team 4-5, Passmore Fall 2016 USF Tampa, Team 4-5, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S4G5
3 名成员
创作了40篇指南
4指南评论
Check also https://www.youtube.com/watch?v=y3CCJtD0...
You don't need to remove the back cover (and don't try it because first, you need to remove the top cover...)
Philippe Combronde - 回复 分享
Where can i buy a replacement button?
Simon Lundh - 回复 分享
You can find the flexible cable with the shutter button on aliexpress:
https://www.aliexpress.com/store/product...
Lac Uster - 回复 分享
Thank you!
Arshad kltn - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 36
过去 30 天: 170
总计 20,129
