简介
If the screen of your Sony Alpha 6000 is damaged and needs to be replaced then this guide is for you. This removal process is susceptible to breakage due to the amount of force that may be required in removing certain components.
你所需要的
Locate and unscrew the two 3 mm screws on the bottom of the screen.
Pull the screen out from the top to reveal the two screws behind the screen; unscrew the two 3 mm screws.
Now your screen is ready to be replaced! To reassemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
