当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
Use a 5.5mm flathead screwdriver to anchor the backing bracket located on the inside of the binding.
Using a Phillips #2 screwdriver, unscrew the countersunk ovalhead M4 x 16mm screw connecting the heel strap ladder to the binding.
Using a Phillips #2 screwdriver, locate and unscrew the countersunk ovalhead M4 x 16mm screw holding the heel strap connector to the binding.
Flip the binding so that the bottom is accessible.
Using your hands, pry off the plastic bottom covering starting at the toe end.
The bottom may still remain attached on the heel edge. There is no need to completely remove it.
Using a Phillips #2 screwdriver, unscrew the button head M4 x 10mm screw holding the toe strap with its connector.
Slide the toe strap off of the toe strap connector.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
