跳转到主内容
加入维修社区 - 创建账户
Snapfon ez One SIM Card Replacement
你所需要的
  1. Snapfon ez One SIM Card Replacement, Remove the battery cover: 步骤 1 中的图像 1,1
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
    询问修复机器人
    添加评论
  2. Snapfon ez One SIM Card Replacement, Remove the battery: 步骤 2 中的图像 1,1
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
    询问修复机器人
    添加评论
  3. Snapfon ez One SIM Card Replacement, SIM Card: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the tweezers,if needed, to grasp the SIM card for removal. Apply a slight pulling tension and remove it from under the tabs as shown.
    询问修复机器人
    添加评论
结论
To reinsert the SIM card or a new SIM card, position the card in the same orientation seen in the figure with the brass connections facing the phone while using thumb to apply a slight force until the card rest inside of the recessed holder. Make sure the brass contacts of the card and phone connect. Then follow the steps in reverse order to reassemble phone.
取消:我没有完成这个指南。
John Bender
于03/26/14注册
818 声望
创作了8篇指南
团队
Clemson, Team 6-5, Benson Spring 2014 Clemson, Team 6-5, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G5
3 名成员
创作了32篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 50
总计 1,545
