跳转到主内容
加入维修社区 - 创建账户
Smart Parts Ion Bolt Replacement
你所需要的
  1. Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: 步骤 1 中的图像 1,3 Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: 步骤 1 中的图像 2,3 Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: 步骤 1 中的图像 3,3
    • Remove the air tank by rotating it counterclockwise.
    • Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin.
    • The pressure gauge will indicate the leftover air in the gun.
    询问修复机器人
    添加评论
  2. Smart Parts Ion Bolt Replacement: 步骤 2 中的图像 1,2 Smart Parts Ion Bolt Replacement: 步骤 2 中的图像 2,2
    • Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
    询问修复机器人
    添加评论
  3. Smart Parts Ion Bolt Replacement, Smart Parts Ion De-Gassing: 步骤 3 中的图像 1,1
    • Turn the gun on by pressing the power button until the red light blinks.
    • Turn vision mode off by pressing the power button again.
    • Red light should be flashing in a double blink sequence.
    询问修复机器人
    添加评论
  4. Smart Parts Ion Bolt Replacement: 步骤 4 中的图像 1,1
    • Pull the trigger to release the air in the gun.
    • Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels, causing embolisms. To avoid this, make sure to point the gun in a safe direction when pulling the trigger because air will be released from the gun.
    询问修复机器人
    添加评论
  5. Smart Parts Ion Bolt Replacement, Grip: 步骤 5 中的图像 1,1
    • Remove the four 8mm screws on each side of the gun's grip using a Phillips #2 screwdriver.
    询问修复机器人
    添加评论
  6. Smart Parts Ion Bolt Replacement: 步骤 6 中的图像 1,1
    • Remove the grip by sliding it towards the front of the gun.
    询问修复机器人
    添加评论
  7. Smart Parts Ion Bolt Replacement, Battery: 步骤 7 中的图像 1,2 Smart Parts Ion Bolt Replacement, Battery: 步骤 7 中的图像 2,2
    • Remove the 9V battery by unsnapping it.
    询问修复机器人
    添加评论
  8. Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: 步骤 8 中的图像 1,3 Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: 步骤 8 中的图像 2,3 Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: 步骤 8 中的图像 3,3
    • Remove the front and rear 1" screws on the gun's grip frame using a 3/32" Allen Wrench.
    询问修复机器人
    添加评论
  9. Smart Parts Ion Bolt Replacement: 步骤 9 中的图像 1,2 Smart Parts Ion Bolt Replacement: 步骤 9 中的图像 2,2
    • Remove the 12 mm screw on the top of the grip frame using a 3/32" Allen wrench.
    询问修复机器人
    添加评论
  10. Smart Parts Ion Bolt Replacement: 步骤 10 中的图像 1,1
    • Separate the gun's body from the frame by gently pulling them in opposite directions.
    询问修复机器人
    添加评论
  11. Smart Parts Ion Bolt Replacement: 步骤 11 中的图像 1,1
    • Remove the 1-1/4" screw that's attached to the blue tube above the front grip using a 3/32" Allen Wrench.
    询问修复机器人
    添加评论
  12. Smart Parts Ion Bolt Replacement, Removing the Solenoid from the Body: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    • Gently use tweezers to detach the white vision wire harness, located directly under the feed tube.
    • Another small tool or your fingers will work for this.
    询问修复机器人
    添加评论
  13. Smart Parts Ion Bolt Replacement: 步骤 13 中的图像 1,1
    • Remove the two 1-1/4" screws on either side of the circuit board using a 3/32" allen wrench.
    询问修复机器人
    添加评论
  14. Smart Parts Ion Bolt Replacement: 步骤 14 中的图像 1,1
    • Separate the solenoid from the gun's body by gently pulling it upwards.
    添加评论
  15. Smart Parts Ion Bolt Replacement: 步骤 15 中的图像 1,1
    • Slide the metal body out of the plastic shell by holding one in each hand and gently pulling apart.
    询问修复机器人
    添加评论
  16. Smart Parts Ion Bolt Replacement, Bolt: 步骤 16 中的图像 1,2 Smart Parts Ion Bolt Replacement, Bolt: 步骤 16 中的图像 2,2
    • Separate the front body breach from the fire chamber by rotating the breach counterclockwise.
    询问修复机器人
    添加评论
  17. Smart Parts Ion Bolt Replacement: 步骤 17 中的图像 1,1
    • Remove the bolt from the front body breach by gently pulling on the bolt.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Shane Villalpando
于02/02/15注册
1,031 声望
创作了10篇指南
团队
Cal Poly, Team 8-42, Amido Winter 2015 Cal Poly, Team 8-42, Amido Winter 2015 的会员
CPSU-AMIDO-W15S8G42
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 41
总计 3,245
