跳转到主内容
加入维修社区 - 创建账户
Slingbox 500 Capacitor Replacement
你所需要的
  1. Slingbox 500 Capacitor Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Remove the sticker on the back of the Slingbox that covers the rear screws using a spudger.
    询问修复机器人
    添加评论
  2. Slingbox 500 Capacitor Replacement: 步骤 2 中的图像 1,2 Slingbox 500 Capacitor Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 7.9 mm rear screws from the device using a Phillips #1 screwdriver.
    • Flip your Slingbox so the bottom is facing upwards.
    • Remove the four 7.9 mm screws using a Phillips #1 screwdriver.
    • You may have rubber feet on the bottom of your Slingbox. If you do, just gently remove them with your hands and set them aside to put back on later.
    询问修复机器人
    添加评论
  3. Slingbox 500 Capacitor Replacement: 步骤 3 中的图像 1,3 Slingbox 500 Capacitor Replacement: 步骤 3 中的图像 2,3 Slingbox 500 Capacitor Replacement: 步骤 3 中的图像 3,3
    • Remove the upper section of the case by rotating your Slingbox to view the back and lifting up on the higher corner.
    • Use the opening tool to disconnect the small clips in the front.
    • These may require some minor force to disconnect.
    • Remove the entire top of the Slingbox and set it aside.
    询问修复机器人
    添加评论
  4. Slingbox 500 Capacitor Replacement, Motherboard: 步骤 4 中的图像 1,2 Slingbox 500 Capacitor Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Remove five 9.5 mm screws from the motherboard using a Phillips #1 screwdriver.
    • Push down firmly on the screws as to not strip them when removing them as they may not spin easily at first.
    • After removing the screws the two metal tabs on either side will be free. Make sure to not bend them or accidentally damage the wires while doing further dissasembly.
    询问修复机器人
    添加评论
  5. Slingbox 500 Capacitor Replacement: 步骤 5 中的图像 1,1
    • Remove the motherboard from the lower case.
    询问修复机器人
    添加评论
  6. Slingbox 500 Capacitor Replacement, Capacitor: 步骤 6 中的图像 1,3 Slingbox 500 Capacitor Replacement, Capacitor: 步骤 6 中的图像 2,3 Slingbox 500 Capacitor Replacement, Capacitor: 步骤 6 中的图像 3,3
    • Check for any damage to or around the capacitor. This can either be burn marks or darkening of the board. The caps of the capacitor may be bulged or even popped. Make sure to check both sides of the board for any damage.
    • If you do find damage, make sure to wash your hands before continuing as some chemicals and components can cause irritation to eyes and skin.
    • Inspect the soldered ends of the capacitors for shorts or accidental soldering bridges. There may also be burns here if a short has occurred.
    询问修复机器人
    添加评论
  7. Slingbox 500 Capacitor Replacement: 步骤 7 中的图像 1,2 Slingbox 500 Capacitor Replacement: 步骤 7 中的图像 2,2
    • Make sure to preheat your soldering iron fully before continuing as a not properly heated iron my cause more damage to the board and connections.
    • Once your iron is fully heated you can press it to the connections on the bottom of the motherboard to melt the existing solder. A solid press for around 2-3 seconds should fully melt the solder.
    • It is not recommended to touch the board or capacitor with your hands as it will likely be very hot after being heated.
    • Once the solder on the bottom is fully melted, you may try and remove the capacitor from the top of the board. You may have to heat it more than once to fully remove the damaged capacitor, but this will not harm the board in any way.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
David Sullivan
于10/18/21注册
365 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-3, Simcock Fall 2021 UMass Dartmouth, Team 1-3, Simcock Fall 2021 的会员
UMASSD-SIMCOCK-F21S1G3
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 30
总计 468
