跳转到主内容
Skullcandy Hesh 3 Charging Port Replacement
你所需要的
  1. Skullcandy Hesh 3 Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,3 Skullcandy Hesh 3 Charging Port Replacement, Charging Port: 步骤 1 中的图像 2,3 Skullcandy Hesh 3 Charging Port Replacement, Charging Port: 步骤 1 中的图像 3,3
    • Start by removing the earmuffs on the speaker side with the charging port. Gently pull from any point of the ear cushion, while also holding on to the base of the speaker.
    • Use a Phillips #00 screwdriver to remove all four 4.0 mm screws securing the faceplate.
    • Remove the faceplate gently without pulling off the wires attached to the speaker and faceplate.
  2. Skullcandy Hesh 3 Charging Port Replacement: 步骤 2 中的图像 1,2 Skullcandy Hesh 3 Charging Port Replacement: 步骤 2 中的图像 2,2
    • Use a soldering iron to heat up the solder at the points where the red, yellow, and black battery cables connect until they detach from the board.
    • Detach the connector on the side of the headphone cup to disconnect the red and black cables (next to the battery cables) from the headphones.
    • Slide the motherboard out of the headphone cup and flip it over.
    • Careful that you don't rip any of the remaining soldered connections (like the speaker connections for example.)
  3. Skullcandy Hesh 3 Charging Port Replacement: 步骤 3 中的图像 1,2 Skullcandy Hesh 3 Charging Port Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to hold the charging port in place, and use a soldering iron to desolder the four soldering points.
    • With tweezers, gently remove the charging port.
    • If there is any resistance, stop immediately to not cause any damage to the motherboard. You may have missed a solder point.
    • Before attaching the new charging port, make sure to clean the previous spot, and remove any residue of adhesive using a connector conditioner and detailing brush.
结论
Emma Lyman
于01/17/23注册
385 声望
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 28
总计 197
