跳转到主内容
Skullcandy Crusher Wireless Battery Replacement
你所需要的
  1. Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: 步骤 1 中的图像 1,2 Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: 步骤 1 中的图像 2,2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Battery Replacement: 步骤 2 中的图像 1,2 Skullcandy Crusher Wireless Battery Replacement: 步骤 2 中的图像 2,2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Battery Replacement: 步骤 3 中的图像 1,1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Battery Replacement, Battery: 步骤 4 中的图像 1,2 Skullcandy Crusher Wireless Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
    • You have to work on the right-side earphone.
  5. Skullcandy Crusher Wireless Battery Replacement: 步骤 5 中的图像 1,3 Skullcandy Crusher Wireless Battery Replacement: 步骤 5 中的图像 2,3 Skullcandy Crusher Wireless Battery Replacement: 步骤 5 中的图像 3,3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker part away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Battery Replacement: 步骤 6 中的图像 1,2 Skullcandy Crusher Wireless Battery Replacement: 步骤 6 中的图像 2,2
    • Separate the headphone speaker assembly from the headphone speaker frame.
  7. Skullcandy Crusher Wireless Battery Replacement: 步骤 7 中的图像 1,3 Skullcandy Crusher Wireless Battery Replacement: 步骤 7 中的图像 2,3 Skullcandy Crusher Wireless Battery Replacement: 步骤 7 中的图像 3,3
    • Remove the battery from the headphone housing.
    • Use a soldering iron to desolder the black, red, and yellow cables from the board and disconnect the battery.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
结论
4等其他人完成本指南。
Val
于03/31/22注册
1,104 声望
创作了6篇指南
团队
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 UMass Dartmouth, Team 1-33, Gurgel Spring 2022 的会员
UMASSD-GURGEL-S22S1G33
1 名成员
创作了12篇指南
4条评论
Hi, Can you specify this replacement batterys name and model number?
kituserkituserkituser kit - 回复
1050mAh, 3,7V 3,885Wh
Mika Björn Wilhelmsen -
Which battery should i buy for my skull candy hes evo??
Lakshit Meena - 回复
donde puedo conseguir la bateria de los skullcandy crusher?
y cual bateria lleva?
pedro landeros - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 45
过去 30 天: 264
总计 9,458
