跳转到主内容
加入维修社区 - 创建账户
SkullCandy Hesh Auxiliary Cable Replacement
你所需要的
    1. SkullCandy Hesh Auxiliary Cable Replacement, Determine the damage: 步骤 1 中的图像 1,1
      • Gently gripping the auxiliary cable of your headset, run your fingers down it's length, feeling for bumps or tears in the plastic sheathing. If there are multiple damaged areas, choose the one closest to the device.
      询问修复机器人
      添加评论
    2. SkullCandy Hesh Auxiliary Cable Replacement: 步骤 2 中的图像 1,1
      • Using wire cutters, cut the auxiliary cable at the determined damaged area.
      • Next, cut your replacement cable to the same length of the removed portion of the damaged cable.
      询问修复机器人
      添加评论
    3. SkullCandy Hesh Auxiliary Cable Replacement: 步骤 3 中的图像 1,2 SkullCandy Hesh Auxiliary Cable Replacement: 步骤 3 中的图像 2,2
      • Using the spudger tool, grip and remove approximately an inch of the plastic sheath from the device's working wire and from the new auxiliary cable.
      询问修复机器人
      添加评论
    4. SkullCandy Hesh Auxiliary Cable Replacement: 步骤 4 中的图像 1,1
      • Use the spudger tool to remove the coating on the smaller colored wires inside the wire attached to the device and the new auxiliary cable.
      • Twist together the same colored wires from the device cable and the new cable.
      询问修复机器人
      添加评论
    5. SkullCandy Hesh Auxiliary Cable Replacement: 步骤 5 中的图像 1,1
      • Wrap each of the individual colored wires with electrical tape to insulate them from the other wires.
      询问修复机器人
      添加评论
    6. SkullCandy Hesh Auxiliary Cable Replacement: 步骤 6 中的图像 1,1
      • Secure all wires with a layer of electrical tape wrapped around the location of the splicing.
      询问修复机器人
      添加评论
结论
Test your device by plugging it into a compatible device using the auxiliary cable and playing a sound.
取消:我没有完成这个指南。
Sarah Burk
于01/15/15注册
247 声望
创作了3篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 57
总计 1,501
