跳转到主内容
加入维修社区 - 创建账户
Sirius Stiletto 100 Volume Button Replacement
你所需要的
    1. Sirius Stiletto 100 Volume Button Replacement, Front Cover: 步骤 1 中的图像 1,2 Sirius Stiletto 100 Volume Button Replacement, Front Cover: 步骤 1 中的图像 2,2
      • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
      询问修复机器人
      添加评论
    2. Sirius Stiletto 100 Volume Button Replacement: 步骤 2 中的图像 1,2 Sirius Stiletto 100 Volume Button Replacement: 步骤 2 中的图像 2,2
      • Use a Philip's head screw driver to remove the screws from the case.
      • Place the screws in a small container to avoid losing them.
      询问修复机器人
      添加评论
    3. Sirius Stiletto 100 Volume Button Replacement: 步骤 3 中的图像 1,3 Sirius Stiletto 100 Volume Button Replacement: 步骤 3 中的图像 2,3 Sirius Stiletto 100 Volume Button Replacement: 步骤 3 中的图像 3,3
      • Remove the front cover.
      • First, insert a small pry bar where the black front cover and white back cover meet.
      • Begin prying the black plastic up, slowing moving around to the bottom and other side.
      • At an angle, carefully pull up on the front cover separate the two pieces.
      • Excellent! Now you have removed the front cover!
      询问修复机器人
      添加评论
    1. Sirius Stiletto 100 Volume Button Replacement, Circuit Board: 步骤 4 中的图像 1,1
      • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
      询问修复机器人
      添加评论
    2. Sirius Stiletto 100 Volume Button Replacement: 步骤 5 中的图像 1,2 Sirius Stiletto 100 Volume Button Replacement: 步骤 5 中的图像 2,2
      • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
      询问修复机器人
      添加评论
    3. Sirius Stiletto 100 Volume Button Replacement: 步骤 6 中的图像 1,1
      • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
      询问修复机器人
      添加评论
    1. Sirius Stiletto 100 Volume Button Replacement, Volume Button: 步骤 7 中的图像 1,1
      • Locate the volume button on the side of the device. The volume button is indicated with an orange rectangle in the photograph.
      询问修复机器人
      添加评论
    2. Sirius Stiletto 100 Volume Button Replacement: 步骤 8 中的图像 1,1
      • Turn the device so that you are looking at the other side of the volume button (from "inside" the device).
      询问修复机器人
      添加评论
    3. Sirius Stiletto 100 Volume Button Replacement: 步骤 9 中的图像 1,1
      • Push on the volume button with both of your thumbs. Wiggle the volume button back and forth as you push upwards.
      • The volume button will pop out.
      询问修复机器人
      添加评论
    4. Sirius Stiletto 100 Volume Button Replacement: 步骤 10 中的图像 1,1
      • Remove the volume button from the device.
      询问修复机器人
      添加评论
    5. Sirius Stiletto 100 Volume Button Replacement: 步骤 11 中的图像 1,1
      • Slide the new volume button into the slot for the volume button.
      • Make sure that the volume button is oriented correctly. An easy way to check this is to hold the volume button in place and look at the side of the device.
      询问修复机器人
      添加评论
    6. Sirius Stiletto 100 Volume Button Replacement: 步骤 12 中的图像 1,1
      • Push down on the volume button to snap it back into the case.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Clemson, Team 2-1, Benson Spring 2012 Clemson, Team 2-1, Benson Spring 2012 的会员
CLEM-BENSON-S12S2G1
3 名成员
创作了18篇指南
1指南评论
Because of the difference between two people in the morning but I'm going&@6899!12;;....,
Rich Ridout - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 29
总计 1,738
