跳转到主内容
加入维修社区 - 创建账户
Siemens A56 Keyboard Replacement
  1. Siemens A56 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
    询问修复机器人
    添加评论
  2. Siemens A56 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
    询问修复机器人
    添加评论
  3. Siemens A56 Keyboard Replacement, Front Plate: 步骤 3 中的图像 1,3 Siemens A56 Keyboard Replacement, Front Plate: 步骤 3 中的图像 2,3 Siemens A56 Keyboard Replacement, Front Plate: 步骤 3 中的图像 3,3
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
    询问修复机器人
    添加评论
  4. Siemens A56 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,3 Siemens A56 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,3 Siemens A56 Keyboard Replacement, Keyboard: 步骤 4 中的图像 3,3
    • The keyboard can be easily removed by hand.
    • Once the old keyboard has been removed, it is possible to replace it with a new keyboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Andrew Corriveau
于03/26/14注册
97 声望
撰写一个指南
团队
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G6
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 48
总计 614
