跳转到主内容
加入维修社区 - 创建账户
Shure SM58 XLR Connector Replacement
你所需要的
    1. Shure SM58 XLR Connector Replacement, Connector: 步骤 1 中的图像 1,3 Shure SM58 XLR Connector Replacement, Connector: 步骤 1 中的图像 2,3 Shure SM58 XLR Connector Replacement, Connector: 步骤 1 中的图像 3,3
      • While holding the microphone connector in one hand, and the XLR cable in the other hand, slowly pull them apart.
      • Make sure you are not holding the microphone connector by the wires.
      • Check to make sure all of the internal wires are connected. If you see a disconnected wire, take a look at the connector soldering guide.
      询问修复机器人
      添加评论
    2. Shure SM58 XLR Connector Replacement: 步骤 2 中的图像 1,2 Shure SM58 XLR Connector Replacement: 步骤 2 中的图像 2,2
      • Hold the microphone connector in one hand and the microphone base in the other.
      • Line up the screw in the connector with the hole in the middle of the microphone.
      • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
      询问修复机器人
      添加评论
    3. Shure SM58 XLR Connector Replacement: 步骤 3 中的图像 1,2 Shure SM58 XLR Connector Replacement: 步骤 3 中的图像 2,2
      • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
      • Do not push the microphone past this point or the connector may become stuck.
      询问修复机器人
      添加评论
    4. Shure SM58 XLR Connector Replacement: 步骤 4 中的图像 1,1
      • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
      添加评论
结论
Following these steps should reinstall the XLR connector back into the microphone.
取消:我没有完成这个指南。
2等其他人完成本指南。
nat coll
于09/27/12注册
859 声望
创作了14篇指南
团队
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G53
5 名成员
创作了74篇指南
2指南评论
kmusic - 回复 分享
simple clear and precise. Small problem fixed in no time, thank you very much!
Kimmo Pekari - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 31
过去 30 天: 99
总计 19,549
