跳转到主内容
加入维修社区 - 创建账户
Sharp Aquos Crystal Screen Replacement
你所需要的
  1. Sharp Aquos Crystal Screen Replacement, Back Panel: 步骤 1 中的图像 1,3 Sharp Aquos Crystal Screen Replacement, Back Panel: 步骤 1 中的图像 2,3 Sharp Aquos Crystal Screen Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
    添加评论
  2. Sharp Aquos Crystal Screen Replacement, USB Port: 步骤 2 中的图像 1,2 Sharp Aquos Crystal Screen Replacement, USB Port: 步骤 2 中的图像 2,2
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
    询问修复机器人
    添加评论
  3. Sharp Aquos Crystal Screen Replacement: 步骤 3 中的图像 1,2 Sharp Aquos Crystal Screen Replacement: 步骤 3 中的图像 2,2
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
    询问修复机器人
    添加评论
  4. Sharp Aquos Crystal Screen Replacement: 步骤 4 中的图像 1,2 Sharp Aquos Crystal Screen Replacement: 步骤 4 中的图像 2,2
    • Disconnect the wire by lifting it up with a plastic opening tool.
    添加评论
  5. Sharp Aquos Crystal Screen Replacement: 步骤 5 中的图像 1,3 Sharp Aquos Crystal Screen Replacement: 步骤 5 中的图像 2,3 Sharp Aquos Crystal Screen Replacement: 步骤 5 中的图像 3,3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    询问修复机器人
    添加评论
  6. Sharp Aquos Crystal Screen Replacement: 步骤 6 中的图像 1,1
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
    添加评论
  7. Sharp Aquos Crystal Screen Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Peel off the black pieces of tape.
    询问修复机器人
    添加评论
  8. Sharp Aquos Crystal Screen Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
    询问修复机器人
    添加评论
  9. Sharp Aquos Crystal Screen Replacement: 步骤 9 中的图像 1,2 Sharp Aquos Crystal Screen Replacement: 步骤 9 中的图像 2,2
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
    询问修复机器人
    添加评论
  10. Sharp Aquos Crystal Screen Replacement: 步骤 10 中的图像 1,1
    • Peel the tape off with your hands.
    询问修复机器人
    添加评论
  11. Sharp Aquos Crystal Screen Replacement: 步骤 11 中的图像 1,1
    • Lift the motherboard out with your hands.
    询问修复机器人
    添加评论
  12. Sharp Aquos Crystal Screen Replacement, Battery: 步骤 12 中的图像 1,1
    • Peel off the tape holding the battery down.
    询问修复机器人
    添加评论
  13. Sharp Aquos Crystal Screen Replacement: 步骤 13 中的图像 1,2 Sharp Aquos Crystal Screen Replacement: 步骤 13 中的图像 2,2
    • Lift the battery out with your hands.
    询问修复机器人
    添加评论
  14. Sharp Aquos Crystal Screen Replacement, Screen: 步骤 14 中的图像 1,1
    • Replace this component with the new one.
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
UMass Dartmouth, Team 7-4, Catania Spring 2016 UMass Dartmouth, Team 7-4, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S7G4
3 名成员
创作了40篇指南
1指南评论
Thanks! I did it!
Matteo Favero - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 18
过去 30 天: 71
总计 11,261
