跳转到主内容
加入维修社区 - 创建账户
Sharp Aquos Crystal Battery Replacement
你所需要的
  1. Sharp Aquos Crystal Battery Replacement, Back Panel: 步骤 1 中的图像 1,3 Sharp Aquos Crystal Battery Replacement, Back Panel: 步骤 1 中的图像 2,3 Sharp Aquos Crystal Battery Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
    添加评论
  2. Sharp Aquos Crystal Battery Replacement, USB Port: 步骤 2 中的图像 1,2 Sharp Aquos Crystal Battery Replacement, USB Port: 步骤 2 中的图像 2,2
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
    询问修复机器人
    添加评论
  3. Sharp Aquos Crystal Battery Replacement: 步骤 3 中的图像 1,2 Sharp Aquos Crystal Battery Replacement: 步骤 3 中的图像 2,2
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
    询问修复机器人
    添加评论
  4. Sharp Aquos Crystal Battery Replacement: 步骤 4 中的图像 1,2 Sharp Aquos Crystal Battery Replacement: 步骤 4 中的图像 2,2
    • Disconnect the wire by lifting it up with a plastic opening tool.
    添加评论
  5. Sharp Aquos Crystal Battery Replacement: 步骤 5 中的图像 1,3 Sharp Aquos Crystal Battery Replacement: 步骤 5 中的图像 2,3 Sharp Aquos Crystal Battery Replacement: 步骤 5 中的图像 3,3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    询问修复机器人
    添加评论
  6. Sharp Aquos Crystal Battery Replacement: 步骤 6 中的图像 1,1
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
    添加评论
  7. Sharp Aquos Crystal Battery Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Peel off the black pieces of tape.
    询问修复机器人
    添加评论
  8. Sharp Aquos Crystal Battery Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
    询问修复机器人
    添加评论
  9. Sharp Aquos Crystal Battery Replacement: 步骤 9 中的图像 1,2 Sharp Aquos Crystal Battery Replacement: 步骤 9 中的图像 2,2
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
    询问修复机器人
    添加评论
  10. Sharp Aquos Crystal Battery Replacement: 步骤 10 中的图像 1,1
    • Peel the tape off with your hands.
    询问修复机器人
    添加评论
  11. Sharp Aquos Crystal Battery Replacement: 步骤 11 中的图像 1,1
    • Lift the motherboard out with your hands.
    询问修复机器人
    添加评论
  12. Sharp Aquos Crystal Battery Replacement, Battery: 步骤 12 中的图像 1,1
    • Peel off the tape holding the battery down.
    询问修复机器人
    添加评论
  13. Sharp Aquos Crystal Battery Replacement: 步骤 13 中的图像 1,2 Sharp Aquos Crystal Battery Replacement: 步骤 13 中的图像 2,2
    • Lift the battery out with your hands.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
9等其他人完成本指南。
团队
UMass Dartmouth, Team 7-4, Catania Spring 2016 UMass Dartmouth, Team 7-4, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S7G4
3 名成员
创作了40篇指南
3指南评论
very helpful. I already replace my sharp 305sh battery
and then I find my power button is out of order.
so i just can keep it still on. use shake to lock screen and touch to unlock.
restart by unplug sim card.
but these day I made it out of power.so it turn off. however I use anyway to make it alive but I can’t.
luck me. I HARDLY PRESS camera left side near down the power button side and press on button .
It turns on.
the power board need to touch on some device on anther side.
!Mucho Gracias!
jeanpaolo lin - 回复 分享
hello, where can I buy this battery ? thanks, Ari
ari leon Kolbar - 回复 分享
battery connector located on motherbaoard has been broken when i was changing my aquos R2 battery.....kind guide me what to do now.....should we use jumper wires direct to the battery ??? if yes then guide me
Masood Ali - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 20
过去 30 天: 93
总计 19,040
