跳转到主内容
加入维修社区 - 创建账户
Shark Rocket HV301 Filter Replacement
你所需要的
    1. Shark Rocket HV301 Filter Replacement, Filter: 步骤 1 中的图像 1,3 Shark Rocket HV301 Filter Replacement, Filter: 步骤 1 中的图像 2,3 Shark Rocket HV301 Filter Replacement, Filter: 步骤 1 中的图像 3,3
      • Locate the orange filter lid on the front of the vacuum.
      • Remove the orange filter lid by pulling on the tab that has "Clean Filter Monthly" written on it.
      询问修复机器人
      添加评论
    2. Shark Rocket HV301 Filter Replacement: 步骤 2 中的图像 1,3 Shark Rocket HV301 Filter Replacement: 步骤 2 中的图像 2,3 Shark Rocket HV301 Filter Replacement: 步骤 2 中的图像 3,3
      • Remove the the outer and inner filters inside the vacuum by pulling them out.
      询问修复机器人
      添加评论
    3. Shark Rocket HV301 Filter Replacement: 步骤 3 中的图像 1,3 Shark Rocket HV301 Filter Replacement: 步骤 3 中的图像 2,3 Shark Rocket HV301 Filter Replacement: 步骤 3 中的图像 3,3
      • Wash the filters by running tap water through them until clear unless you are buying new filters.
      • Lay thee filters out until they are completely dry.
      询问修复机器人
      添加评论
    4. Shark Rocket HV301 Filter Replacement: 步骤 4 中的图像 1,3 Shark Rocket HV301 Filter Replacement: 步骤 4 中的图像 2,3 Shark Rocket HV301 Filter Replacement: 步骤 4 中的图像 3,3
      • Locate the motor filter lid on the top of the vacuum with the vacuum facing you.
      • Remove the motor filter lid by pushing the release clip on the top and pulling towards you.
      询问修复机器人
      添加评论
    5. Shark Rocket HV301 Filter Replacement: 步骤 5 中的图像 1,2 Shark Rocket HV301 Filter Replacement: 步骤 5 中的图像 2,2
      • Pinch the tab on the motor filter to remove it from the vacuum.
      添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
Christian
于10/06/16注册
478 声望
创作了2篇指南
团队
Cal Poly, Team 10-5, Livingston Fall 2016 Cal Poly, Team 10-5, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S10G5
4 名成员
创作了25篇指南
12指南评论
great! I had an extra filter in a package of filters I bought and couldn't for the life of me figure there that one on top of the motor went. I haven't changed it since I bought the cleaner 2 years ago!
randy thill - 回复 分享
My motor filter is now almost completely black. Is that normal?
chanel a - 回复 分享
Nope. If it’s cloth, wash it with soap and water, toss it in the drier, and put it back in. If it’s washable but not cloth, wash it, let it dry - good to go
Robin Wenz - 回复 分享
Am I missing something? Isn’t the conclusion a little premature? The filter in the back, are we able to clean it or not? A couple of YouTube videos on the subject say not to clean this filter. When my vacuum is under load and they close off the suction I immediately have a loss of suction power and loud suction noise out the back. Basically it is losing almost all the suction power out the back when the vacuum is under load. This happens regardless if I have the filter in or out so I can’t imagine cleaning it will make much difference. I have cleaned all my other filters. Other than that the vacuum sounds like it’s working well. I can’t find any other information on the topic. This is not happen to anyone else? Thank you for any help and also if you could clarify if we can clean the filter in the back or not as well that would be great. My apologies if this was already mentioned somewhere in the video earlier on. May want to include it at the end when discussing that particular filter anyways?
Bilbo - 回复 分享
Can I rinse the motor filter?
Ashley Stilabower - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 44
过去 30 天: 254
总计 55,326
