跳转到主内容
加入维修社区 - 创建账户
Shark Pet Perfect II Battery Replacement
你所需要的
    1. Shark Pet Perfect II Battery Replacement, Battery: 步骤 1 中的图像 1,3 Shark Pet Perfect II Battery Replacement, Battery: 步骤 1 中的图像 2,3 Shark Pet Perfect II Battery Replacement, Battery: 步骤 1 中的图像 3,3
      • Locate and remove the 7.5mm Philips screw holding the battery cover in place on bottom of the vacuum.
      询问修复机器人
      添加评论
    2. Shark Pet Perfect II Battery Replacement: 步骤 2 中的图像 1,3 Shark Pet Perfect II Battery Replacement: 步骤 2 中的图像 2,3 Shark Pet Perfect II Battery Replacement: 步骤 2 中的图像 3,3
      • Once the cover is removed, slide the plastic retaining bracket down and pull out to remove.
      询问修复机器人
      添加评论
    3. Shark Pet Perfect II Battery Replacement: 步骤 3 中的图像 1,3 Shark Pet Perfect II Battery Replacement: 步骤 3 中的图像 2,3 Shark Pet Perfect II Battery Replacement: 步骤 3 中的图像 3,3
      • Pull the battery out of the compartment.
      • Carefully disconnect the quick disconnect couplers.
      • The Couplers may be tightly secured so it may be necessary to use a small flat device to carefully loosen the coupler.
      • Be sure to use an ESD safe tool like the nylon spudger when working with wires and batteries—this will prevent injury and/or device damage.
      询问修复机器人
      添加评论
    4. Shark Pet Perfect II Battery Replacement: 步骤 4 中的图像 1,1
      • Completely remove the old battery from the vacuum .
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
附加文件
团队
UW Tacoma, Team S1-G5, Liner Summer 2017 UW Tacoma, Team S1-G5, Liner Summer 2017 的会员
UWT-LINER-SU17S1G5
4 名成员
创作了12篇指南
12指南评论
Removed the single screw but cover will not come off. What do you do?
Adalyn Etelamaki - 回复 分享
Just tried it. The cover is a bit hard. Gold the vacuum at an angle and slightly push the notch on the cover with a flat screwdriver, it should come out.
PradSim Promo Ads - 回复 分享
Will it run on cord only
ligthelf - 回复 分享
NO. Requires batteries.
Jim DeCamp - 回复 分享
1.) Mine was much harder to disassemble, took considerable force.
2.) No one sells form, fit and function replacement batteries, including Shark
3.) The available replacement are much smaller in volume, and hence power, and require padding or they will rattle.
Jim DeCamp - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 84
总计 19,978
